wastegate questions
Old Dec 13, 2012 | 11:34 AM
cwalker2006's Avatar
Default wastegate questions
is there a way to tell if one is failing? when i first put the turbo kit on it was a steady 7 psi. ive added since then a tbss intake, 3 1/2 exhaust into a 4'' muffler. i have a manual boost controller and i thought that was it so i turned it all the down. still is a constant 10-11 psi. Any siggestions?
Old Dec 13, 2012 | 11:35 AM
nonnieselman's Avatar
you freed up the exhaust and lowered the back pressure so the wastegate doesnt have much to push it open any more.. i ran into that when i first opened my cutout and saw 25+psi on a 5.8# spring.... Cutout closed it wont go over 5psi.
Old Dec 13, 2012 | 11:40 AM
do i need to get a stiffer spring?
lighter spring.
whats in there now?
Old Dec 13, 2012 | 11:42 AM
what was in there when i bought the kit. supposed to be 7lbs i think.
Old Dec 13, 2012 | 11:43 AM
are they color coded? if so i can take it apart tomorrow morning and post a picture
Old Dec 13, 2012 | 01:03 PM
TrickTurbo's Avatar
Truck Sponsor
Depending on gate most are color coded.
Just need to install a lighter spring back so your base psi is reached.
Spring ratings are just a starting point. So many things can effe g final psi not just the gate.
Old Dec 13, 2012 | 01:18 PM
ask me how i know.. hahah
i learned that not too long ago at the track.
Old Dec 14, 2012 | 12:07 PM
i went part throttle last night and hit almost 15 psi. where can i get the springs at?
Old Dec 14, 2012 | 01:06 PM
what brand wastegate??
