wastegate questions...
Old Dec 11, 2008 | 03:43 PM
  #21
ducky's Avatar
Originally Posted by shawnss
thats cool atleast you found the problem nothings worse than have something wrong with your truck and not knowing what it is. that makes sense why your not hearing the WG cause when your butterfly on the throttle body closeing your WGs not opening cause the extra boost is going out of the hole instead of back though the turbo.
exactly. and whats even better then knowing its not something serious, is now the boost controller and BOV go on, and im gonna turn that **** up a few pounds
ill probably upgrade to better clamp connectors on the couplers
Old Dec 12, 2008 | 11:32 PM
  #22
bud8fan's Avatar
glad you found your problem ducky...
Old Dec 13, 2008 | 08:16 AM
  #23
TG02Z71's Avatar
Did you hear any weird rubbing sounds over the last couple months that just went away??
Glad you found your problem!
Old Dec 13, 2008 | 03:42 PM
  #24
ducky's Avatar
actually no I didnt. before the hole I did notice that there was a crevice there from where it had rubbed, btu I actually thought someone made it like that so it would clear the sway bar
Old Dec 15, 2008 | 05:29 AM
  #25
silver-mod-o's Avatar
Hunt&Fisherator
I've got one small place where an intercooler pipe runs right up against the swaybar so I took a sheet of rubber and wrapped the swaybar and tie-wrapped it to the swaybar just so this very thing wouldn't happen.... Might want to consider something similar....
Old Dec 23, 2008 | 03:12 AM
  #26
t-bolt clamps FTW!
GMCtrk
Oct 20, 2015 06:17 AM
LSX-81-SIERRA
Oct 2, 2015 07:05 AM
Tuckin15s
Sep 23, 2015 09:35 PM
97_ek
Sep 23, 2015 09:16 PM
