wastegate psi ???
Old Dec 28, 2007 | 01:05 PM
Default wastegate psi ???
i was wondering right now there is a 10 psi spring in the wastegate. if i want to run less boost with a manual boost controller,and just turn it up when i want to do i have to get a smaller spring, like a 5 psi spring???
Thanks!!
Old Dec 28, 2007 | 01:30 PM
dan96z71's Avatar
sounds right to me. Throw a 5 psi spring in there and then the boost contoller will hold the spring shut until the psi you have chosen. I was looking into the Voodoo Boost last night.
Old Dec 28, 2007 | 02:13 PM
WJ MARK's Avatar
yep thats exactly what you need to do.
Old Dec 28, 2007 | 02:59 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
That's the only way you can run less boost (change springs).
Old Dec 28, 2007 | 03:53 PM
explorer5.0's Avatar
TOTM: November '07
You will only be able to run about twice the spring pressure in boost before exhaust starts pushing though.
Old Dec 28, 2007 | 04:32 PM
so basically a 5 psi spring will yield 10 psi max??
Old Dec 28, 2007 | 04:33 PM
with boost controller of course
Old Dec 28, 2007 | 04:59 PM
TOTM: November '07
roughly, yes.
Old Dec 28, 2007 | 05:03 PM
ok thats what i thought im new to turbos so i kinda didnt think i could use a 10psi spring and get lower boost (matter of physics) thanks!!!!!!!!!!!
03sierraslt
14
Oct 9, 2015 05:53 AM
turbo6c3
Oct 5, 2015 06:11 PM
LSX-81-SIERRA
Oct 2, 2015 07:05 AM
old motorhead
Sep 29, 2015 08:22 PM
