What is a/r?
Old Dec 27, 2007 | 01:00 PM
14 Second Truck Club
Default What is a/r?
I see all the turbos have an a/r .xx, what does it stand for? What does it do? Thanks.
Old Dec 27, 2007 | 01:14 PM
Mort's Avatar
A/R = Area/Radius
Area = area of the inlet of the turbine or the outlet of the compressor
Radius = radius from the centre of the turbo wheels to the the centre of the area of the turbine inlet or compressor outlet.
Compressor performance is comparatively insensitive to changes in A/R. Larger housings can be used to optimize low boost applications.
Exhaust performance is greatly affected by changes in A/R. A smaller A/R increases throttle response and a larger A/R increases overall power.
General description from the Garrett site Turbo Tech 101
Old Dec 27, 2007 | 01:15 PM
Mort's Avatar
Originally Posted by NegraRCSB2X4auto
air to fuel ratio
That would be AFR not A/R...LOL
Old Dec 27, 2007 | 05:33 PM
Spoolin's Avatar
GFYS and STFU
Lol...delete delete delete!!!
Old Dec 28, 2007 | 02:44 AM
Originally Posted by Mort
A/R = Area/Radius
I think I get it now. Like a 5000lb truck from a roll would want a smaller a/r to build boost quick and make the torque to get a bunch of weight going. Where a lighter vehicle (camaro) from a roll would want a larger a/r to pull hard on the top-end. Right?
Old Dec 28, 2007 | 04:53 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Maybe. It depends a lot on how you size the turbos. A lot of guys size turbos the way they size cams IMO -- too big. Yeah, a smaller turbo will make less comparative power, but it's that same old "under the curve" argument.
If your turbo is too big for the application, you will get crazy *** lag -- but since lag is expected from a turbo, a lot of people just accept it or try to fix it with a smaller A/R housing (which chokes the turbine effectively on the top of the efficiency curve).
Soap box aside, with the turbo sized "correctly", a smaller A/R gets you into boost sooner, but at the expense of top end power. A larger A/R gets you into boost later, but with more top end power.
I have what I think is going to be small A/R housings on my twins now because I wanted Radix like lag on the street (where 1000+ hp is a liability anyway ), if I am not satisfied with what they crank out, I will put on two larger housings for glory track / dyno days.
To put it another way, I couldn't do variable vane technology like on diesel rigs (where the computer controls the vanes), but wanted similar performance -- grunt when having fun, powah when being serious about things.
Old Dec 28, 2007 | 08:14 PM
NegraRCSB2X4auto's Avatar
hell yeah lol.
kha4079
Oct 29, 2018 04:38 PM
kush killer
Feb 17, 2016 09:20 PM
GMCtrk
Oct 20, 2015 06:17 AM
LSX-81-SIERRA
Aug 31, 2015 05:52 PM
08lambochevy
Aug 7, 2015 11:42 PM
