wastegate problems.
Old Oct 9, 2013 | 05:51 AM
TrickTurbo's Avatar
Truck Sponsor
Seal ring in place?
Massive back psi?
What's the build specs and turbo specs?
Gates piston not seal between top/bottom pots?
Did you contact kb for his input?
Old Oct 9, 2013 | 07:22 AM
blacksheep's Avatar
Seal ring is in. I don't know what the back psi is. Stock 6.0 with gt2/3 cam, kb t6 kit with s480 1.32ex, 4 inch down pipe. Bench tested the gate and it seems to work fine everytime. Have not asked kb yet.
Old Oct 9, 2013 | 07:24 AM
TrickTurbo's Avatar
Truck Sponsor
What RPM are you spinning it to?
Old Oct 9, 2013 | 08:53 AM
blacksheep's Avatar
Old Oct 9, 2013 | 10:23 AM
kbracing96's Avatar
OK, here's my theory, that turbo has a huge hot side, the WG is big, you have pretty much no back pressure before or after the turbo with the 4" DP. The WG cracks just a little and you loose the pressure differential across the turbo which is what it needs to spool the turbo.
Solutions, put on a smaller WG or restrict it so it flows a lot less. Block off 1/2 of the scroll to make more pre-turbo back pressure, put smaller exhaust after the 4" DP... IDK, lol. I think you just need more back pressure to spool the turbo...
Maybe the WG needs to be in the cross over where it won't work...
Old Oct 9, 2013 | 11:03 AM
blacksheep's Avatar
The 4 inch dp goes into a 3 inch flowmaster cat back. I guess I'll just throw some co2 on the gate and see what happens. I took this kit off my 2wd changed the log and nothing else made 12psi on other truck and 4psi on this truck.
LSX-81-SIERRA
Oct 2, 2015 07:05 AM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
97_ek
Sep 23, 2015 09:16 PM
MOBBN
Sep 22, 2015 08:07 PM
