wastegate problems.
Old Oct 8, 2013 | 07:41 PM
blacksheep's Avatar
Default wastegate problems.
I know this has been cover before but I'm having boost problems. 6.0 with Kb kit w/s480 and jgs50 gate in the log. With 2 washers, smaller spring and just the top port referenced I'm only getting 7psi. With no references it only makes 3.8psi. Any ideas before I stack both springs?
Old Oct 8, 2013 | 07:49 PM
Atomic's Avatar
I have a gauge for that
Use compressed air on the lower port to make sure the valve has its full range of movement.
Old Oct 8, 2013 | 07:54 PM
blacksheep's Avatar
It does, checked it earlier today.
Old Oct 8, 2013 | 07:58 PM
Chevy_King1500's Avatar
top port should be vented if you're not using some type of controller,
if you unhook the vacuum lines completely it only makes 3.8 psi?
Old Oct 8, 2013 | 08:07 PM
blacksheep's Avatar
Unreferenced= 3.8psi
Referenced bottom port only= 1psi/115kpa
Referenced top port only= 7psi.
Looking for 10-11psi. This kit made 12psi on my other truck with the bottom wg port referenced.
Old Oct 8, 2013 | 08:17 PM
Gadgetized's Avatar
It sounds like the gate is leaking air.
Old Oct 8, 2013 | 08:20 PM
blacksheep's Avatar
It not leaking, it just opens at those pressures.
Old Oct 8, 2013 | 08:29 PM
Atomic's Avatar
Have you checked for a massive exhaust leak somewhere on the hot pipes?
With the top referenced that turbo should make 40psi before you can lift
Old Oct 9, 2013 | 12:49 AM
blacksheep's Avatar
Stacked the springs and had the same out come. No exhaust leaks that I can find or hear. Cold side is vband and checked them as well.
Old Oct 9, 2013 | 04:56 AM
bud8fan's Avatar
wow...you would think it was leaking by pretty bad
