Wastegate issues
Old Mar 14, 2012 | 07:27 AM
  #31
HIPSI's Avatar
Even when I took the mbc off and hooked it direct it still didn't work.
Old Mar 14, 2012 | 07:38 AM
  #32
RibeiroBJJ's Avatar
Praise The Lowered
Get a new wastegate..Sounds like yours no worky...
Old Mar 14, 2012 | 07:50 AM
  #33
454SuperSport's Avatar
make sure the bottom of the wastegate is bolted to the crossover, its a lot easier to put it on backwards than most people think.
Old Mar 14, 2012 | 08:04 AM
  #34
HIPSI's Avatar
Its on right..
Old Mar 14, 2012 | 09:11 AM
  #35
bud8fan's Avatar
sounds like the diaphram is jacked up again.
Old Mar 19, 2012 | 01:56 PM
  #36
HIPSI's Avatar
Well I tryed a diff wg with a 7lb spring and same thing happened then put my old one on and took the spring completely out and it still made boost... Precision turbo FTW!
Old Mar 19, 2012 | 02:07 PM
  #37
Wilde Racing's Avatar
How do I change this text
As I said before the gate is most likely froze up. Pull it apart and verify the valve moves freely.
Old Mar 19, 2012 | 03:40 PM
  #38
HIPSI's Avatar
valve moves fine... I can hear the wg open as soon as I crank it.
Old Mar 19, 2012 | 06:12 PM
  #39
Just because it opens doesn't mean it's opening all the way....
Old Mar 19, 2012 | 06:16 PM
  #40
HIPSI's Avatar
so u think even with the spring out and it ref off the compressor housing that its still not opeing all the way? Im begining to think the wg is just too small.
