Wastegate issues
Old Mar 11, 2012 | 07:59 PM
  #21
HIPSI's Avatar
Hell I've had it to 15 on a 7lb spring... Im gonna take the 10lb spring and cut a coil or 2 out of it and strech it back out to size...
Old Mar 11, 2012 | 10:30 PM
  #22
TrickTurbo's Avatar
Truck Sponsor
Have you tried just taken the spring out and seeing what happens?
Cutting and stretching a spring just ruins the spring.
It will never perform the same once that type if mod is done.
Old Mar 11, 2012 | 11:02 PM
  #23
Wilde Racing's Avatar
How do I change this text
Don't modify springs, it doesn't sound like that is going to help. You need to verify the gate is opening fully. A long time ago I had an over boost due to a gate that was not opening fully.
Old Mar 12, 2012 | 07:16 AM
  #24
HIPSI's Avatar
That will be next...
Old Mar 12, 2012 | 09:45 AM
  #25
kbracing96's Avatar
The top port is completely open on your WG right? You didn't put a plug in it or anything did you? You need to run the boost line strait to the manifold with a new piece of hose, then T- off that to your vac block. Or if your compressor cover is taped for a 1/8npt fitting, run that strait to your WG instead. It just sound like your WG is not fully opening or getting a good signal from the manifold (leaking some where).
Old Mar 12, 2012 | 12:03 PM
  #26
HIPSI's Avatar
top port is open i'll try running it to the compressor housing...
Old Mar 12, 2012 | 01:47 PM
  #27
Atomic's Avatar
I have a gauge for that
NO! That will cause you to overboost!
You need to run the line from the compressor housing to the bottom port and leave the top port open.
Old Mar 12, 2012 | 05:17 PM
  #28
HIPSI's Avatar
Ya... Thats what I ment...
Old Mar 13, 2012 | 07:39 PM
  #29
HIPSI's Avatar
I just tryed it ref off the comp housing thru the halmans mbc and it seems worse... Boost seems to get there alot quicker on the gauge.
Old Mar 13, 2012 | 09:15 PM
  #30
Daryn's Avatar
Formerly darynC-10/23/10
take off the boost reg, leave the 10 psi spring in and ref it off the compressor housing, of its over boosting after that, you may have a bad diaphragm or you need a better wastegate, I ran a tial 44 in a forged 6.2 at 10 psi and had no problems , it was ref off the compressor housing
