Wastegate issues
Old Feb 29, 2012 | 12:14 AM
tummys10's Avatar
Where is you vac block tapped in at?
Old Feb 29, 2012 | 06:02 AM
Half-bred's Avatar
I had thesame problem with over boosting and then I moved the wastegate to blow to the ground and it works fine. I think there is to much back pressure in the exhaust I'm going to try to take the muffler off and see if it works without the muffler
Old Feb 29, 2012 | 07:26 AM
HIPSI's Avatar
Vac block is referenced off the manifold.
Old Feb 29, 2012 | 07:28 AM
HIPSI's Avatar
I may try that... I tryed it before but my wg was jacked up then.That would mean the wg is too small if that works?
Old Feb 29, 2012 | 09:13 AM
FarmTruc's Avatar
Performance Trucks Sponsor
bench test the wg with an air gun and boost gauge to ensure the spring is actually what you're trying to achieve.
Old Mar 7, 2012 | 08:18 PM
HIPSI's Avatar
Changed the spring out from the 10 to the 7 and it starts to check up at 7 then goes on up to whatever I want...
Old Mar 7, 2012 | 09:02 PM
Gadgetized's Avatar
Check to see if the diaphram is leaking(It could be leaking more when it is hot). If it isn't leaking, check the PSI at the wastegate when the boost is climbing. If it isn't climbing at the wastegate like your gauge, you need a better place to tap into for your wastegate. If it is climbing like your gauge, the wastegate or something behind it is too restrictive. How big is your wastegate? Do you have it vented back in the exhaust system?
Old Mar 8, 2012 | 06:21 AM
HIPSI's Avatar
40mm jgs back into the exhaust 3.5" dp into a 4" exhaust
Old Mar 11, 2012 | 01:18 PM
HIPSI's Avatar
Well I just flipped the wg to vent into the atmosphere and with the 7lb spring u start to here it crack open at 4psi and then I let off around 11psi so its still over boosting
Old Mar 11, 2012 | 07:41 PM
Atomic's Avatar
I have a gauge for that
then the wastegate is too small or you just need to run more boost
