Wastegate on crossover pipe
Old Jun 15, 2015 | 02:30 AM
Mzay's Avatar
Registered User
Default Wastegate on crossover pipe
Hi there, I was wondering if anyone runs a wastegate on their turbo cross over pipe. I'm looking for a place to weld in my wastegate and so far, the cross over pipe would be the easiest, but I'm not sure how effective it would be considering it's not catching/routing the exhaust gas from the other side of the engine. I found this kit on the forum, and I was planning on fabbing the wastegate the same way. So my question is does this method work? How Well? Any input would be greatly appreciatedName:  image_7.jpg
Old Jun 15, 2015 | 09:23 AM
kbracing96's Avatar
Yes, It works just fine. Myself and Trick have built hundreds, if not thousands of these type setups. Only ever been very few issues with boost control and I attribute most of those to other factors.
Old Jun 15, 2015 | 09:32 AM
Atomic's Avatar
I have a gauge for that
Works fine for your typical 70-80mm turbo setup on a typical 5.3-6L engine. With a bigger turbo or bigger engine you may want a second gate somewhere.
Old Jun 15, 2015 | 09:51 AM
George C....'s Avatar
Formerly ScreamingL
Works for the smaller turbos and motors as stated get into big boy territory and gate placement needs addressed
Old Jun 15, 2015 | 10:36 AM
TrickTurbo's Avatar
Truck Sponsor
WOW that's an old picture. That's from
I would say 1000's.
That location has been been used for 10years or better.
Works good on all applications as long as the gate is matched to engine/boost/power range.
Exp. 39mm gate on a 427 trying to run 5psi not happening.
Like mentioned I only know of a couple that boost control issues.
Swap to a larger gate problem solved.
Old Jun 15, 2015 | 10:49 AM
black6spdz's Avatar
I run a 50mm gate in that spot and run from 10psi to 25psi with a 6.0. It does spike some on the shift but is tolerable
Old Jun 15, 2015 | 11:13 AM
Mzay's Avatar
Registered User
I've got a 6.0 lq4. I'm running a cheap ebay turbo
http://m.ebay.com/itm/190592393465?txnId=1134354469009
Old Jun 20, 2015 | 09:48 PM
shorty's garage's Avatar
What if it is like this?
Old Jun 24, 2015 | 09:48 PM
robbyredneck's Avatar
im running the same setup. as the gods have said. it works fine
03sierraslt
14
Oct 9, 2015 05:53 AM
BlownHD
Oct 3, 2015 12:24 PM
LSX-81-SIERRA
Oct 2, 2015 07:05 AM
sTNT971
Sep 26, 2015 04:22 PM
