WARNING to Bosch 044 owners
Old Jun 27, 2010 | 07:01 PM
  #21
charcold-bowtie's Avatar
i was prewarned to run big gauge wire and be prepared to use 2 relays when my big pump goes in, and use the stock wired to trigger them.
Probably order 2 of those kits
Old Jun 27, 2010 | 07:17 PM
  #22
sureshot's Avatar
Sorry, this is the only pic that turned out ok on my phone. The wires go through the grommets and are attached directly to the pump via ring terminals. The ground wire gets grounded using the same bolt that grounds the filler neck. The power wire runs along the frame in a wire loom directly to the relay in the fuse box.
Old Jun 27, 2010 | 07:25 PM
  #23
phasemaster1's Avatar
FUG those wires are big compared to stock. Wires tight going threw the grommets?
Old Jun 27, 2010 | 07:48 PM
  #24
sureshot's Avatar
Yeah, they were really tight. We used some gasket maker around the grommets before we put the tank bank up, just to make sure nothing could get in.
Old Jun 27, 2010 | 08:16 PM
  #25
bluchev's Avatar
holy ****, is that 8 gauge?
Old Jun 27, 2010 | 08:17 PM
  #26
fastnblu's Avatar
Acc. to 1st post, it's 10 ga.
  #27
sureshot's Avatar
It's 10 gauge wire. The coating on the wires is thick, very high quality.
Old Jun 28, 2010 | 12:39 PM
  #28
blownss06's Avatar
What kind of wire is that? It looks like speaker wire from the pic. Also is it gas proof?
Old Jun 28, 2010 | 03:58 PM
  #29
sureshot's Avatar
No, they aren't speaker wires. They are ok to be in gas, oil, etc.
Old Jul 4, 2010 | 12:39 AM
  #30
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
Thanks for the info, but where did you get the grommets from, and what size are they??
