wanting more boost
Old Dec 17, 2005 | 04:25 AM
whoopassracer's Avatar
Default wanting more boost
i want to get more boost out of my radix and im running it with a 10lb pulley which i dont know exact the inches on it, but if correct its a 3.00. And i want to go with a smaller pulley, but dont want to blow my motor. and suggestions on getting the most boost out of my truck.
Old Dec 17, 2005 | 12:25 PM
PappyDan's Avatar
Tribe Shaman
what have you done to your motor so far to make it more boost efficient.
cam
heads
headers
filter system
tune
exhaust
fuel system
injectors
and so on.
as I have told other before, boost can start off at a base of 10 horses per pound of boost.
by changing things on the motor like injectors, fuel system, air filter, cam shaft, heads and most important the tune can take that 10 horse base per pound and up it making more power per pound of boost.
I know it is easy to up the pressure and add 2 to 4 more psi on boost by making the pulley smaller but what have you done to make the same boost pressure more powerful.
Old Dec 17, 2005 | 12:27 PM
BlownChevy's Avatar
blownerator
25 Year Member
why dont you add more timing? I still dont see why everyone goes right for the boost. You are reaching the point of dimishing returns, get a custom dyno tune.
Old Dec 17, 2005 | 12:30 PM
ogkevin13's Avatar
Banned
injectors, fuel pump, meth or intercooler, but watch you IAT. AND MOST IMPORTANT A BOMB *** TUNE (CHASSIE DYNO)
Old Dec 17, 2005 | 12:36 PM
TurboGibbs's Avatar
A $85 pulley is easier and cheaper than a custom tune. Most people don't work with a tuner. Besides, I did both. I ought to be the poster child....Now see kids, this is what not to do! 3 out of 4 pistons on the left bank gone in about .3 seconds with no indication of KR. It had to be water.
A custom tune will do wonders. Just from experience, if you get into knock retard, back the timing down 2-3 degrees at least for insurance. Not just 1 degree like I did. Unless you arn't concerned about blowing it, as I was not.
Old Dec 17, 2005 | 03:04 PM
well i have the radix with intercooler and edelbrock headers, 43lb injectors, 80mmtb, intake, nelson performance tuning transgo reprogramming shift kit with new zpak clutches, maf, electric fans, borla exhaust. i just wand to get into the 12's or maybe just installing a 2600 stall would get me there
Old Dec 17, 2005 | 05:45 PM
PappyDan's Avatar
Tribe Shaman
looks like the next step would be a good cam, stall, and a update on the tune.
Old Dec 17, 2005 | 08:54 PM
04Denali's Avatar
whoopassracer,
How do you like your 80mm throttle body? what kind? any issues? How did you conect to your Radix Air tube?
Tanks,Mark
Old Dec 18, 2005 | 01:02 AM
MNC5's Avatar
Originally Posted by mjhoward
2005 Joe Gibbs 4.8 5spd(originally N/A) Magnacharger Radix 3.00 pulley 12 lbs boost with Gomer tune
Custom Intercooler heat exchanger 3x the size
216/224 .558 114 Lsep, Comp 918's
Meth injection
3.73 w/ Detroit Trutrac
445 RWHP 489 TQ with 30* timing, now has 3 busted pistons
12.58 @ 109.1 full weight. Oh yeah, stock trany & stock clutch on slicks.
Owch..30 degrees of timing on 12lbs, bet she ran hard for those .3 seconds.
Old Dec 18, 2005 | 01:44 AM
my throttle body is by bbk
