wanting more boost
i want to get more boost out of my radix and im running it with a 10lb pulley which i dont know exact the inches on it, but if correct its a 3.00. And i want to go with a smaller pulley, but dont want to blow my motor. and suggestions on getting the most boost out of my truck.
what have you done to your motor so far to make it more boost efficient.
cam
heads
headers
filter system
tune
exhaust
fuel system
injectors
and so on.
as I have told other before, boost can start off at a base of 10 horses per pound of boost.
by changing things on the motor like injectors, fuel system, air filter, cam shaft, heads and most important the tune can take that 10 horse base per pound and up it making more power per pound of boost.
I know it is easy to up the pressure and add 2 to 4 more psi on boost by making the pulley smaller but what have you done to make the same boost pressure more powerful.
cam
heads
headers
filter system
tune
exhaust
fuel system
injectors
and so on.
A $85 pulley is easier and cheaper than a custom tune. Most people don't work with a tuner. Besides, I did both. I ought to be the poster child....Now see kids, this is what not to do! 3 out of 4 pistons on the left bank gone in about .3 seconds with no indication of KR. It had to be water.
A custom tune will do wonders. Just from experience, if you get into knock retard, back the timing down 2-3 degrees at least for insurance. Not just 1 degree like I did. Unless you arn't concerned about blowing it, as I was not.
well i have the radix with intercooler and edelbrock headers, 43lb injectors, 80mmtb, intake, nelson performance tuning transgo reprogramming shift kit with new zpak clutches, maf, electric fans, borla exhaust. i just wand to get into the 12's or maybe just installing a 2600 stall would get me there
Originally Posted by mjhoward
2005 Joe Gibbs 4.8 5spd(originally N/A) Magnacharger Radix 3.00 pulley 12 lbs boost with Gomer tune
Custom Intercooler heat exchanger 3x the size
216/224 .558 114 Lsep, Comp 918's
Meth injection
3.73 w/ Detroit Trutrac
445 RWHP 489 TQ with 30* timing, now has 3 busted pistons
12.58 @ 109.1 full weight. Oh yeah, stock trany & stock clutch on slicks.
Meth injection
