vortech with high boost...will it make any sound
Old Oct 8, 2005 | 11:35 AM
bourbeaugmcx's Avatar
Post vortech with high boost...will it make any sound
well, just 6 pounds......it doesn't really make any boost noise, or i just can't hear it over my exhaust???? ....but if i go to 10 pounds will she make some noise for me.
thanks for any help......ryan
Old Oct 8, 2005 | 05:53 PM
greentahoe's Avatar
My S trim is pretty loud with a 3.12 pulley. I may throw a 2.87 on there until I get the bigger motor in there as the T trim is a bit of over kill for this little 5.3 I think
Old Oct 9, 2005 | 01:20 PM
i keep forgeting me and you are the only vortech owners
Old Oct 9, 2005 | 01:33 PM
Deckhand's Avatar
Old Oct 9, 2005 | 06:46 PM
greentahoe's Avatar
Originally Posted by Deckhand
Have you decided to go bypass or blowoff?? I have a feeling there will be more talk about vortechs on our trucks in the near future.
Old Oct 9, 2005 | 09:43 PM
idk yet...i like to spend money on beer more than parts....it sucks!!!!
Old Oct 9, 2005 | 10:04 PM
Deckhand's Avatar
For now I will probably use the stock bosche bypass, but I would like to get the vortech Maxflo bypass.
Im wondering if I should use the 3.33 pulley, or order a smaller one right off the bat since I want at least 450 rwhp (in the 6.0L).
I ordered my cam from cam motion, and have the rest of the accessories on the way.
Old Oct 10, 2005 | 09:30 PM
greentahoe's Avatar
definately go with the smaller pulley. Power doesnt come on for us like it does with the Radix. The 3.33 doesnt make crap for power other than on a dyno. Go with at least a 3.12. you may want to go smaller if you dont have a converter. Ive got a PI VIG 3000 that is pretty aggressive.
Old Oct 10, 2005 | 10:57 PM
Deckhand's Avatar
would I need a new belt going from a 3.33 to the 3.125?
Old Oct 11, 2005 | 09:12 PM
greentahoe's Avatar
no. Im using the same belt. Im pretty sure its 113". Im going to go with a 111" when I go down again though. I do get some slip (squeeling) if I let off the throttle in the higher rpms but I think that is do to the inlet to the bypass not being larger enough. You are supposed to have a 1.5 ID tube to the larger bypass valve and I rigged it to the tube that was already on the inlet tube to the TB.
