vortech with high boost...will it make any sound
Old Oct 12, 2005 | 10:45 AM
Deckhand's Avatar
Originally Posted by greentahoe
no. Im using the same belt. Im pretty sure its 113". Im going to go with a 111" when I go down again though. I do get some slip (squeeling) if I let off the throttle in the higher rpms but I think that is do to the inlet to the bypass not being larger enough. You are supposed to have a 1.5 ID tube to the larger bypass valve and I rigged it to the tube that was already on the inlet tube to the TB.
So you mounted the vortech maxflo already? Where did you weld the flange to?
Old Oct 14, 2005 | 09:42 PM
greentahoe's Avatar
I got a 1.5" ID 90* pipe and cut a hole with a hole saw into the pipe coming out of the blower leading into the intercooler. I simply welded the 1.5" pipe to that and have the blowoff mounted there. Its a little farther over on the passenger side since to get the pipe to fit over the TB I had to find a 2.75" pipe and could only find it in aluminum and then used a 2.75" to 3" reducer to mount it to the 3" pipe with a 45* bend to get it over to the 90* bend where the airbox was and down to the FMIC. This whole thing was much more of a pain in the *** than I had originally anticipated.
TX Tahoe Z71
Sep 1, 2015 09:11 PM
V-seriesTech
Jul 28, 2015 12:31 PM
lxcoupe
Jul 21, 2015 02:12 AM
Ferocity02
Jul 17, 2015 07:05 PM
rojeho
Jul 12, 2015 06:10 PM
