Very Little Boost...8.1L Rear Mount
Old May 16, 2009 | 04:02 PM
  #31
Wilde Racing's Avatar
How do I change this text
I still say check the waste gate function...
Old May 16, 2009 | 05:40 PM
  #32
Ender06's Avatar
Its raining now, Ill have to check it tommorow.
Old May 16, 2009 | 07:49 PM
  #33
Spoolin's Avatar
GFYS and STFU
Does your waste gate dump to the atmosphere? If it does do you hear it open? (vid would help) Also if it's routed back into the exhaust disconnect it at the flange so it does dump to the atmosphere and you can hear it. If it is stuck open or opens at all during your test you should be able to hear it clearly. Since it's already disconnected you shouldn't hear it open at all. Do this and it will determine whether or not your wastgate is faulty like dusty is saying.
Old May 16, 2009 | 07:59 PM
  #34
Ender06's Avatar
Call me dumb, but this thing is LOUD. How do I know if the wastegate is open or not? What sound should I hear? Just louder exhaust?
Old May 16, 2009 | 08:04 PM
  #35
Whippled 496's Avatar
WhoooooooooooooooooooBBSHHHHHHHHHHHHHHHHH
Old May 16, 2009 | 08:08 PM
  #36
Ender06's Avatar
HA ha, but thanks, I think that might be the whole problem!
Old May 16, 2009 | 08:11 PM
  #37
Ender06's Avatar
oh yea, what causes them to stick, how can i prevent it?
Old May 16, 2009 | 09:07 PM
  #38
Spoolin's Avatar
GFYS and STFU
Ok check it out...
In the following vids you can hear the truck (V8) then you can hear the whistle of the turbo and you can start to hear the waste gate opening and eventually it drowns EVERYTHING out to where you only hear the exhaust escaping through the waste gate. That's what your listening for...if you can hear the turbo and truck getting drowned out by the loud "whoosshh" and your wastegate is disconnected then it is like Dusty said and your wastegate is stuck open and not allowing enough exhaust to spin the turbo.
http://www.youtube.com/watch?v=Qzp3-pUavkU
Around second 19-20 you can hear it start to open and around second 24 the wastegate is wide open and is drowning evertthing else out.
Old May 16, 2009 | 09:21 PM
  #39
Spoolin's Avatar
GFYS and STFU
In this vid around second 07 you hear the wastegate openening full bore and drowning out everything else. Again my wastegate is routed to the atmosphere which is why it is soo loud but it allows you to really tell IF it is allowing it to open, WHEN it opens and maybe problem solve it as well. Do this and you'll know if your wastegate is stuck open.
http://www.youtube.com/watch?v=TImPCEfGm6c
If it is stuck open it will sound similar to mine.
If it is closed it will sound like....maybe this...
http://www.youtube.com/watch?v=W_6OG4xQEjQ
(note, not gonna find a turbo without a wastegate but this one sounds like it's routed back into the exhaust...picked something with alot of power cuz the turbo's are usually loud as ****)
Old May 16, 2009 | 09:33 PM
  #40
Ender06's Avatar
Spoolin, THANKS, I AM hearing the woosh just like that, which i thought was the 'leak' at first, but that is what it HAS TO BE.
