venting crankcase
Old Feb 14, 2014 | 10:01 AM
Atomic's Avatar
I have a gauge for that
Pass cover connected to a Tee with one side going to the valley cover where I drilled a taped a 3/8" fitting and the other side going to the driver side to another Tee which goes to a vented catch can.
Bigger issue is if you are having a lot of blow by you may want to consider how the rings and pistons look...
Old Feb 14, 2014 | 10:15 AM
Vortec350ss's Avatar
I kind of assumed that he was forcing air in through the valve cover vent... his bottom end has very little miles on it so I would think they're good.
Old Feb 14, 2014 | 10:26 AM
silverado.408's Avatar
Valve cover breathers. A couple buddies with high horsepower boosted high dollar 370 -390- 408 that just vent to atmosphere. No problems to my knowledge I did it to my wife N/A z28. No problems just gets dirty a little faster just change it sooner
Old Feb 14, 2014 | 10:43 AM
Atomic's Avatar
Oh, well if he is pressurizing the crankcase by way of the factory PCV system that is his fault
SYRacing's Avatar
I had this setup for about 2 days and got sick of the Rotella T smell
Old Feb 14, 2014 | 11:03 AM
boostedsl2's Avatar
plumbing to a catch can with a filter (atmosphere) but plumbing a line to the intake will get rid of most of the smell.
I hate it too. took me a while to figure that out lol
Old Feb 14, 2014 | 11:15 AM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
Originally Posted by Blown06
Mine did the same thing when I was on a d1sc. I have a catch can that I welded a couple hose barbs in so that it connects directly with each stock valve cover. It's an aluminum can with a breather on top. I'm not using it so if you want it let me know.
i send you a pm
Originally Posted by Byrdman11
Did you install a one way check valve in the Pcv? Did not you are putting boost in the crank case.
nope i have a non vented catch can so i should probably buy a one way check valve
Originally Posted by 6.0l RST
soooo much to cleaannnn.
you got that right
why not just get a oil fill with a filter on it and cap off the original vent location?
i can but i Hurd its gonna smell like oil since its just vented to the atmosphere
Originally Posted by GRRR65GTO
I just posted up some pictures of the catch can in my thread. I ran 3/8 hose from both valve covers to it
ill take a look
How is your current pcv system setup?
stock I'm just a dumbass for not setting it up right i was itching to take the truck out for a ride
Filers are on a catch work great. You can always add a line from the catch can before the TB (or turbo inlet) to pull a little vacuum at idle to suck the catch can smell.
here's a few photos of my setup
[/QUOTE]
looks like a really nice setup
Old Feb 14, 2014 | 11:23 AM
03sierraslt's Avatar
Stock routing works fine if you do it right. Attach the fresh air breather in front of the blower after the air filter. Attach the driver side valve cover to the intake manifold with a one way check valve so you don't boost your crankcase. If you are pulling oil vapors then put a catch can between the drivers side valve cover and the intake manifold. For anyone that has breathers attached to the valve cover and is pulling vac from the intake to anywhere on the motor then you are pulling un metered air and if you are MAF tuned then you may have some idle issues.
Old Feb 14, 2014 | 11:24 AM
Putting a bit of vacuum on your bottom end is a good thing.
Old Feb 14, 2014 | 12:41 PM
Ferocity02's Avatar
I use the stock PCV system with a check valve and catch can inline. The check valve prevents the boost in the intake from going through the PCV lines into the crankcase.
And then I run a single 3/8" line from the passenger side valve cover to the turbo inlet pipe.
I was worried that the single 3/8" line wouldn't be enough to vent the crankcase while in boost, but it seems to be working fine. I've never pushed out the dipstick. I may upsize the line anyways and plumb it from the oil filler cap to the turbo inlet.
