venting crankcase
Pass cover connected to a Tee with one side going to the valley cover where I drilled a taped a 3/8" fitting and the other side going to the driver side to another Tee which goes to a vented catch can.
Bigger issue is if you are having a lot of blow by you may want to consider how the rings and pistons look...
Valve cover breathers. A couple buddies with high horsepower boosted high dollar 370 -390- 408 that just vent to atmosphere. No problems to my knowledge I did it to my wife N/A z28. No problems just gets dirty a little faster just change it sooner
I had this setup for about 2 days and got sick of the Rotella T smell
Fastest D1 Procharged Truck
you got that right
stock I'm just a dumbass for not setting it up right i was itching to take the truck out for a ride
Filers are on a catch work great. You can always add a line from the catch can before the TB (or turbo inlet) to pull a little vacuum at idle to suck the catch can smell.
here's a few photos of my setup
looks like a really nice setup
Stock routing works fine if you do it right. Attach the fresh air breather in front of the blower after the air filter. Attach the driver side valve cover to the intake manifold with a one way check valve so you don't boost your crankcase. If you are pulling oil vapors then put a catch can between the drivers side valve cover and the intake manifold. For anyone that has breathers attached to the valve cover and is pulling vac from the intake to anywhere on the motor then you are pulling un metered air and if you are MAF tuned then you may have some idle issues.
I use the stock PCV system with a check valve and catch can inline. The check valve prevents the boost in the intake from going through the PCV lines into the crankcase.
And then I run a single 3/8" line from the passenger side valve cover to the turbo inlet pipe.
I was worried that the single 3/8" line wouldn't be enough to vent the crankcase while in boost, but it seems to be working fine. I've never pushed out the dipstick. I may upsize the line anyways and plumb it from the oil filler cap to the turbo inlet.
