venting crankcase
Old Feb 13, 2014 | 10:44 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
Default venting crankcase
well i took my truck out for a quick ride the other day and blew the dipstick out and soaked the engine with oil
so whats the best way to vent the crankcase
Old Feb 13, 2014 | 10:47 PM
timmay208's Avatar
ditch the pvc and do a catch can
Old Feb 13, 2014 | 11:26 PM
Blown06's Avatar
8 Second Truck Club
Mine did the same thing when I was on a d1sc. I have a catch can that I welded a couple hose barbs in so that it connects directly with each stock valve cover. It's an aluminum can with a breather on top. I'm not using it so if you want it let me know.
Old Feb 14, 2014 | 06:21 AM
Byrdman11's Avatar
Did you install a one way check valve in the Pcv? Did not you are putting boost in the crank case.
Old Feb 14, 2014 | 07:28 AM
6.0l RST's Avatar
soooo much to cleaannnn.
Old Feb 14, 2014 | 08:07 AM
Vortec350ss's Avatar
why not just get a oil fill with a filter on it and cap off the original vent location?
Old Feb 14, 2014 | 08:53 AM
GRRR65GTO's Avatar
I just posted up some pictures of the catch can in my thread. I ran 3/8 hose from both valve covers to it
Old Feb 14, 2014 | 09:09 AM
03sierraslt's Avatar
How is your current pcv system setup?
Old Feb 14, 2014 | 09:24 AM
boostedsl2's Avatar
I would ditch the PCV valve all together. You can weld/plug the port on the tb and run the lines to a catch can. you'll also need to plug the port on the intake.
Filers are on a catch work great. You can always add a line from the catch can before the TB (or turbo inlet) to pull a little vacuum at idle to suck the catch can smell.
here's a few photos of my setup
Old Feb 14, 2014 | 09:43 AM
GMCtrk's Avatar
I have a vented catch can attached to my drivers side valve cover (I drilled out the Pcv valve). And I have a line from my air filter to the passenger valve cover to pull vacuum on the crankcase under boost.
