vent crankcase help
Old Jul 30, 2011 | 07:53 PM
Sweetser54's Avatar
Default vent crankcase help
didnt vent my crankcase and now im blowin white smoke and loosing oil. i was wanting some advice on what you guys did. my buddy says the pressure from crankcase may be blowing out the rear main seal under boost and when u let off after boosting it. maybe seals in the turbo?
kb racing turbo kit. 78mm, low boost 5pounds. 91 octane. good valve springs and a turbo cam. 6.0 ls.
Old Jul 30, 2011 | 08:40 PM
milkey57's Avatar
Kinda depends on your ride. I have my driver side valve cover to the manifold with a check valve and catch can between the two. Then the driver side valve cover goes to the inlet in front of my procharger (vacuum source). Hope this helps some, and hope the engine is ok...how much smoke and oil?
Old Jul 30, 2011 | 08:43 PM
Mangled03gmc's Avatar
Baltimore Whore
Vent the pass side valve cover, run a ls6 valley cover or simply drill, put a vent in the current cover..
Old Jul 31, 2011 | 10:06 AM
02'Z71ONDUBZ''s Avatar
At the very least, vent the pcv and the pass side cover and cap everything else off. This is what I have done. You could run a catch can setup if you wanted, but its not a must.
Old Jul 31, 2011 | 10:22 AM
TXsilverado's Avatar
i went with the newest ls6 valley cover design.
Old Aug 1, 2011 | 12:48 PM
Sweetser54's Avatar
thanks to everyone. this is the only thing i have left to do and it should be perfect!
Old Oct 17, 2011 | 07:51 PM
bad cutt's Avatar
how did you vent the pcv?, and if i seal the valve covers and just run an elbow from the valley to my catch can would that be sufficient?
Blwn99x
Mar 24, 2023 11:14 AM
Avalanche2002
Nov 30, 2015 07:31 AM
turbo6c3
Oct 5, 2015 06:11 PM
carid
Oct 1, 2015 09:22 AM
the owl
Sep 4, 2015 04:09 PM
