vacuum leak at closed throttle.
Old Nov 12, 2016 | 12:56 PM
crashmymax's Avatar
Default vacuum leak at closed throttle.
Having a hard time tracking down small vacuum leak. It is only apparent at closed throttle. Does this norrow down the posable places for the leak? Checked all the lines themselves and all are good. Sprayed carb cleaner around different connections not getting anywhere. Any thoughts? Thinking it may be the cause of my check engine light.
Old Nov 12, 2016 | 01:04 PM
JordanH's Avatar
Restricted
Where's your boost/vac reference from?
Old Nov 12, 2016 | 01:56 PM
crashmymax's Avatar
Boost/vac is from the computer not a line. Using dashlogic.
Old Nov 12, 2016 | 03:22 PM
JordanH's Avatar
Restricted
Gotcha... what's vac show at idle? There's a little reference port on the passenger side of the intake, is the tab still connected on it? Is this a new motor? Who put the intake manifold on?
I had hell trying to track down a leak on mine one time, but figured it out when I noticed one of my injector lock clips were missing! I let a friend put the intake manifold on and he somehow got that clip wedged inbetween the intake and head on #8 port. Also when I pulled the intake, I ditched the factory intake gaskets for the metal fel-pro ones with the thick silicone gaskets. These are far better than the factory ones, in my opinion.
Old Nov 12, 2016 | 03:30 PM
crashmymax's Avatar
Using that for my wastegate. Have the truck apart now so cant start it. Will let you know idle vac later. Looking for a good spot to tap the compressor housing for manual boost controller right now.
Old Nov 12, 2016 | 05:48 PM
JordanH's Avatar
Restricted
I'd say anywhere on the snout will be fine... maybe closer to the compressor wheel end
Old Nov 12, 2016 | 06:30 PM
crashmymax's Avatar
I was hoping there would be a flat spot to drill and tap no such luck but got it done anyway. Vac at idle cold was 8#. Warmed up it was 11#. Think i am going to get a pressure regulator for my compressor and charge the system with 3# of air. Then hose her down with soapy water.
Old Nov 12, 2016 | 10:01 PM
JordanH's Avatar
Restricted
Is that a new motor? thats a good idea to try and find a leak! Keep us updated!
Old Nov 12, 2016 | 10:21 PM
crashmymax's Avatar
It was a remanufactured motor. Probably have about 3,000 miles on it now maybe 4. Have not driven much in the last 5 month's. I will let you no how it goes will probably do it monday. Thanks for helping.
Old Nov 12, 2016 | 11:07 PM
JordanH's Avatar
Restricted
No problem! I remember all the setbacks you've went through! If that's a stock motor, then that vac seems low to me. It's more than likely gonna be something simple... besides all that, have you got to run it good get, and did you find a good tuner?
