Vacumm
Old Sep 26, 2007 | 06:54 AM
Default Vacumm
I am finishing up my front mount turbo.
How do I connect the vacum line off of the valve covers?
Should I just tap a fitting on to my air filter?
Is there any other vaccum lines that I need to change?
Thanks
Old Sep 26, 2007 | 07:53 AM
TG02Z71's Avatar
Are you asking about a boost reference signal hookup or some type of crankcase EVAC system?
Old Sep 26, 2007 | 07:58 AM
Vacumm line, evac system and if I should change any other lines?
Old Sep 26, 2007 | 08:13 AM
TG02Z71's Avatar
Did you buy a particular system or is this home built? Need more information on your set up.
EVAC system may be needed if you are pressurizing your crankcase from ring blow-by.
The vacuum line is strictly for the waste gate or BOV signal. Two completely different things here.
More will chime in on this, got to go to work now.
grm1738
Jun 5, 2014 10:25 PM
BUTTERB30
Feb 10, 2013 09:07 PM
buccnazty
Dec 23, 2012 01:45 PM
nicky g
Aug 10, 2010 08:22 AM
Cam51
14
Mar 5, 2006 12:07 AM
