making progress on my turbo project
Old Feb 10, 2013 | 05:37 PM
BUTTERB30's Avatar
Default making progress on my turbo project
so last post i was having problems with oiling and i believe i have that problem solved lol. So now everything is connected except the down pipe to exhaust but my question is while driving shouldn't i feel some kinda of power boost from the turbo cause it feels the same before the turbo if not less power hummmmm. i do have my bov installed with the lightest spring no vacumm ports connected and waste gate set with the 5 pound spring. whats you guys input THANKS!
Old Feb 10, 2013 | 05:54 PM
Atomic's Avatar
I have a gauge for that
Uhh I suggest you hook everything up before you drive it. And get it tuned.
holley2346's Avatar
Have you upgraded your plugs?
Tune it before your boost it...
Old Feb 10, 2013 | 05:59 PM
TrickTurbo's Avatar
Truck Sponsor
Tuned? If not it will not make any power.
Bov needs to be hooked up.
No down pipe? So how the gate hooked up. Wasn't this a low mount set up?
And what was the fix to the problem?
Old Feb 10, 2013 | 06:37 PM
BUTTERB30's Avatar
YES this is the low mount set up and for the oiling prob it was getting to much oil cause i forgot to reinstall the oil restrictor. now for the driving i just couldnt help my self and ive been driving around say a two mile little stretch of road. waste gate is on with both banjos barbs not connected same for the bov, truck runs and idles pretty good for non tune just loud of course without down pipe connected to stock exhaust. and were is the good spot for the bov to connect into as far as vaccumm and rick do u have and low mount instructions for yr kit you can email just to check over my setup and correct various probs lol
Old Feb 10, 2013 | 06:49 PM
GMCtrk's Avatar
You really need to park that thing before you blow it up. If it's a JGS gate, hook a port from the intake manifold to the lower barb. Top barb is for a boost controller.
Old Feb 10, 2013 | 07:40 PM
TrickTurbo's Avatar
Truck Sponsor
No instructions.
Post up your pics for review.
Driving and trying to boost with no tune bad idea.
Just cruising is no biggy.
Old Feb 10, 2013 | 09:07 PM
Link2603's Avatar
As stated above get it tuned. Also you need to have some gauges hooked up so you can see how much boost your are getting. Also get a fuel pressure and AFR gauge.
SLOPONY
20
Oct 18, 2016 06:05 AM
chopperloco
Jul 10, 2016 10:45 PM
Ammadien
Jul 22, 2015 08:50 PM
black6spdz
Jul 16, 2015 01:32 AM
Mzay
Jul 6, 2015 11:03 PM
