Using stock manifold for turbo??
Old Jan 14, 2012 | 01:40 PM
Thanks man. I have 4 sets of stock manifolds. One from my truck, one from my ls3 Camaro, one from a ls1 gto and the ones I'm using from my old ls1 Camaro. Im using the Camaro ones bc they fit best and the exhaust exit on them is at the best angle for my setup. I even mixed and matched to see what works best and the ls1 Camaro manifolds work best but I have seen guys using stock truck manifolds and they can work well too
Old Jan 14, 2012 | 06:31 PM
black04silverado's Avatar
Thanks guys for the links and the information!
I really like the clean look of running the crossover pipe behind the motor has anyone done this? or can it even be done?
Old Jan 14, 2012 | 07:03 PM
Bowtie502's Avatar
I think all of the kb trick, etc etc kits ALL cross behind the motor
Old Jan 14, 2012 | 07:40 PM
Yea they are. They use the factory driver side manifold and utilize a log type manifold on the passenger side. The crossover connects to the rear of the log and the log has a 90 degree bend in the front and the turbo mounts on top
Old Jan 14, 2012 | 09:22 PM
kbracing96's Avatar
Like this?
Old Jan 15, 2012 | 04:08 AM
yes kyle just like that.
just go ahead and send me one of them.
Old Jan 15, 2012 | 09:56 AM
kbracing96's Avatar
That can be arranged
Old Jan 15, 2012 | 05:39 PM
pm me the best you can do on a hot side set up with some oil lines.shipped to 73072
Old Jan 15, 2012 | 08:25 PM
LPRacing's Avatar
i just did a set for mine, flipped and facing forward, cut the flanges off and ground them all down and welded 2.5 inch v-band flanges to them. i am using v-band housing precision turbos so it will be real simple v-band to v-band with a small bend in between with enough room to mount wastegates....but i am contemplating welding the wastegates to the manifolds
5.3Okasai
Mar 9, 2022 01:07 PM
OHsixLS3
Dec 27, 2016 09:30 AM
thunder550
Oct 8, 2015 04:53 PM
lxcoupe
Jul 21, 2015 02:12 AM
black6spdz
Jul 16, 2015 01:32 AM
