two step ???
The msd version is so easy to install and works badass. You just tap into brake pedal for signal, make 2 connections on coil packs, and set rpm. It activates when you press brake and unleashes the power when you let off. Cant picture why timing is even touched on the lingenfelter unit.
I am also 4180lbs in street trim and plan to be 4200 driver and all race weight
NICE
