Twin turbos on 8.1/496
Old Oct 7, 2008 | 02:53 PM
  #21
Kerr's Avatar
this topic sucks with you dyno graph and freaking videos!!!!
Old Oct 13, 2008 | 02:00 AM
  #22
ok, first of all the only way a single turbo is more efficient is in terms of cost. two smaller turbos like a pair of 3082R's or perhaps a pair of 35r's would spool faster than a large single, and you'd still have great top end. if you wanted to run a larger single, a T78 or an sp74, or a gt47R would still spool fairly fast. not as fast as the twins, but still pretty quick with 8 liters of displacement. either way, with all that displacement, i'd reccomend a pair of 50mm wastegates, and a pair of 50mm bov's. the sheer mass of air concerned with all that displacement warrants it. have fun though. looking forward to pics.
Old Oct 13, 2008 | 01:52 PM
  #23
Kerr's Avatar
good post want a supra, BUT the 8.1L only revves to 4800 rpms
So if you go to big your lag vs rpm comeinto play. Also these motors make 455lbtq right off idel, so if you boost to low in the rpm range the just snoke tires for ever...
P.S. i got a supra ill sale ya
Old Nov 26, 2009 | 01:01 PM
  #24
xx_ED_xx's Avatar
I will be putting twins on my 8.1 powered scsb 04 silverado
Old Nov 26, 2009 | 02:27 PM
  #25
Rick_Vor's Avatar
Originally Posted by gnimelf4
I am interested to know if anyone has put twin turbos on a 8.1? I have 2001 2500HD with an allison tranny and am primarily looking for towing power. I pull a 48ft gooseneck with around 13,000 pounds. I'm not nessesarily looking for max power at high RPM (but wouldn't mind smacking a muskrat every now and then either) and would like to know what size turbos I should look for? How much boost is possible with the stock setup? Any guidence would help.
I love turbos. They are fun, sound awesome and twins are cool but if I was building something for your application, I go straight for a Roots or Whipple. 48' 13k pound trailer doesnpt need 500wrhp at 6000 rpms. You need 600lbs torque at 2500 rpm to put that beast up a grade.
Rick
Old Nov 26, 2009 | 02:45 PM
  #26
Rick_Vor's Avatar
Couldn't be more true. Most of the high end OEM's have gone to twin turbos versus singles to give the big cubic feel down low and still pull good on the top. Look at BMW's 3.0l straight 6 with two itty-bitty turbos. 300 ft lbs of torqe at 1800 rpm and still pulls 300 HP on the top. Compare that to a Subruru WRX 2.5l with a single that hits 300hp on top but only has 175 lbs of torque at 2000rpms.
If you do go the turbo route, the displacement will be part of the equation to determine A/R ratios but is irrelevent when deciding the size of the wastegates and BOV's. A kit builder will recomend the proper size componemts to compliment your turbo(s). If the turbo(s) will efficiently move enough air to produce say 600hp, it will be at 35lbs on a 2l and 12 lbs on a 8l. The BOV and wastegate is based off the volume of air the turbo(s) produce. I've seen plenty of kits that break 800 WRHP with only a pair of 30mm wastegates and a single 50mm BOV for a twin kit or single kits with a 40mm wastegate and 50mm BOV.
Rick
kha4079
Oct 29, 2018 04:38 PM
lxcoupe
Sep 6, 2017 08:24 AM
chvy=power
Sep 8, 2015 11:06 AM
slowswb
Sep 5, 2015 02:27 PM
06murder
Sep 4, 2015 03:54 PM
