TVS2300 on an 8.1L.....thoughts, opinions, feedback.
#23
I think there havin a hard time wrapping there head around how much air the 8.1l moves. LOL
#27
Its a standard 2.3L compressor.
James B, has had this same issue as well as a few other 8.1L people who just cant make enough boost for the 8.1L with a Whipple. If you look on Whipples site in the marine section you can see the different setups for the 8.1Ls. Their lower performance setups (5psi or less) use the W140ax (2.3L) compressor. The higher performance setups (6psi and +) use the W200ax (3.3L) compressor. So its seems apparent that Whipple also understands that the 2.3L compressor will not get the job done on these 8.1Ls over 5psi. At least not thier compressor anyway (Brian says the TVS will even though its the same size) Right Brian?....Right? You add the Air to water intercooler core to my setup and you loose a little more boost.
#29
Actually it would be cool to see a TVS cross flow chart of how much boost you would create, given cylinder volume vs blower speed if someone smarter than me (and God knows there are plenty out there) would like to do it.
#30
High on diesel fumes
Ahh I gotcha...I was wondering how much that thing was overdriven, doesn't sound like too much. I know the numbers that I have seen with the TVS are all overdriven to produce a peak of anywhere from 14-18 psi. I guess it would be a little soft down low if it was only peaking at 6psi.
