TVS1900 Gauge sensor install questions
Old Apr 10, 2010 | 03:43 PM
Chavette's Avatar
Default TVS1900 Gauge sensor install questions
For the TV1900, trying to get all the parts before I start adding the gauges...
Fuel Pressure Gauge: Adding electronic sensor, has someone replaced the test port on rail with a sender (concerned about amount of thread)? For an adapter on the rear of the rails can someone confirm the flex fuel hose connectors at rails are AN-6? If this is correct I plan to go with 100199erl fitting for my 1/8 NPT sender.
Vacuum/Boost Gauge: Running PVC hose, any recommendations on best line/location to tie into and if used a t-fitting or ?
Last edited by Chavette; Apr 11, 2010 at 09:55 AM. Reason: Updated original unanswered post questions
Old Apr 11, 2010 | 10:33 PM
tylerhinz's Avatar
Just installed both last week. There is a schraeder valve on the fuel rail I just removed that added a brass t fitting for room and screwed my dfuel pressure sender on top of it. Very simple and looks good. All fittings are 1/8npt. There is a nipple on the back of the supercharger you can run your boost gauge tube of and wont need any t fittings.works really well only need about 6inches of hose to mount the sender to your firewall. Hope this helps a bit
Old Apr 11, 2010 | 10:47 PM
guero68's Avatar
man sounds nice..havent thought of that one for the fuel pressure gauge
Old Apr 12, 2010 | 06:59 AM
Chavette's Avatar
Thanks for the feedback. I might put the sender directly in place of the valve. On the boost don't recall a nipple back there, but I will get a mirror and look. Thanks again.
Old Apr 12, 2010 | 07:21 AM
turboescalade's Avatar
I did the same thing. only I didnt put in a T. I just screwed in the fuel pressure sensor and grinded my coil pack holder a bit.
thunder550
Oct 8, 2015 04:53 PM
zblee
Aug 3, 2015 03:45 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
FlowmasterMufflers
Jul 9, 2015 12:23 PM
FlowmasterMufflers
Jul 9, 2015 12:00 PM
