Tvs1900
Old Nov 22, 2011 | 09:10 PM
TX Tahoe Z71's Avatar
Originally Posted by 05 vortec high output
So 6.0 make less boost than 5.3/4.8
All else equal, yes
01silvy's Avatar
Yes it has bigger cubes and produces less boost.. thats why magnuson came out with the 2300 for the larger 6.2.. your 5.3 might make 12 psi with the tvs 1900, then you swap the 1900 to a 6.0 and it might make 8-9 psi then you put it on a 6.2 and it might max out at 6-7 psi.. bigger cubes produce lower boost unless you spin the maggie faster.. but superchargers have a rpm limit just like engines do.
Old Nov 23, 2011 | 01:40 AM
McAllenSS's Avatar
I'm running an LQ4,L92's 1-7/8 ARH, water/meth mix, 8 rib with the 2.7 and im reading 13lbs
Old Nov 23, 2011 | 06:25 AM
05 vortec high output's Avatar
To get more boost I can get a 10% overdrive crank pulley, smaller s/c pulley
rednekferlife101
32
Jan 8, 2016 10:42 PM
Albertachevy
Sep 22, 2015 10:28 PM
dselby25
Aug 24, 2015 07:26 PM
kbracing96
Sep 6, 2009 01:38 AM
