TVS cam specs
Old Apr 22, 2009 | 02:51 PM
EVILGMC's Avatar
Originally Posted by thunder550
Will the LSA and LS9 cams work in the GENIII engines? Do they have the reluctor ground into the rear of the camshaft?
im not sure...
Old Apr 22, 2009 | 07:35 PM
TURBHOE's Avatar
i think you need the gear and front cover for the ls2's to run those cams. then just extend the wires for the sensor.
Old Apr 23, 2009 | 03:04 AM
EVILGMC's Avatar
cam being built today. 224/230 .600/.600 116
home to have it all back together by sunday.
Old Apr 23, 2009 | 04:39 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
So even though most of the maggy cams that work really well have over a 10* split you still went with only a 6* split?
Old Apr 23, 2009 | 05:27 PM
EVILGMC's Avatar
i have had a 224/228 on 114 and liked it.
i have had a 208/230 on 121 and hated it.
so im tryin something in the middle.
Old Apr 23, 2009 | 07:14 PM
TURBHOE's Avatar
let us know how it goes.
Old Apr 23, 2009 | 08:06 PM
Mr. Sandog's Avatar
Why?
Why?
Old Apr 23, 2009 | 09:12 PM
EVILGMC's Avatar
the gt-7 121* was dead in the mid range. maybe it just wasnt a good pairing with my 4l80e. it would make good boost, but only felt really strong down low...dead mid range and then a peak before shifting.
the 114* custom felt solid all the way thru the powerband....on and off boost. dyno numbers were similar, but this one pulled harder on less boost and did not have the dead spots like the 121* so im trying something more similar to this one with some influence from the LEP maggie cam.
this is all with a stock converter on a truck thats 99% street driven.
i decided on the specs after talking with a number of people on here and in the industry.
im excited...the cam is ready now...but could not get to the shop to pick it up today after work.
Old Apr 23, 2009 | 11:08 PM
BuiltNotBought's Avatar
Sounds like its coming along Patrick.
Old Apr 24, 2009 | 09:07 AM
BigTex's Avatar
I had excellent results with a single pattern 218/218 114 cam in my SSS. Doing it again, I wouldn't hesitate to run a 220/224 or 224/224 cam. I don't think it needs 10* more exhaust as long as you have a well designed exhaust system. Those lingenfelter cams run great with stock manifolds and stock exhaust though.
