>>TVS 2300 Denali Conversion RCSB <<
Old Sep 26, 2017 | 06:49 PM
  #91
smokinlmm's Avatar
Magnaflow installed! Sounds great. Anybody have any expirence with Mayhem in Raleigh? I spoke with them today and liked what I was hearing. I'm thinking of ordering the long tubes, y-pipe (should I have a custom x pipe made instead?) and 8 rib pulley set so I can pulley down and get the boost up around 10. At this point do I need meth?
Old Sep 28, 2017 | 06:28 PM
  #92
smokinlmm's Avatar
Got my gauges!!!
Old Sep 28, 2017 | 07:49 PM
  #93
Tig's Avatar
Tig
You have PM
Old Oct 2, 2017 | 10:48 PM
  #94
smokinlmm's Avatar
&gt;&gt;TVS 2300 Denali Conversion RCSB &lt;&lt;-screenshot_20171002-234308.png
&gt;&gt;TVS 2300 Denali Conversion RCSB &lt;&lt;-screenshot_20171002-234301.png
Got my gauge pod, needs work but I can fix it. Also ordered a few more things...
Old Oct 3, 2017 | 10:31 AM
  #95
ZO6Ted's Avatar
Good to see its coming along. I made 10 on the dyno for some strange reason. Whipple 2.9 kit with stock pulley and 6 rib. Probably because of restrictive stock exhaust I'm guessing. No meth needed...
Old Oct 3, 2017 | 07:27 PM
  #96
smokinlmm's Avatar
This thing needed major attention before my OCD would let it anywhere near my truck. I got the x series to fit and then saw the crack so i marine texed it and left it to set up. I also built up one side a bit just to make it perfect. Next is SEM dye and install it all...
Old Oct 4, 2017 | 06:30 PM
  #97
smokinlmm's Avatar
Maggie in the house!!!
Old Oct 4, 2017 | 06:42 PM
  #98
smokinlmm's Avatar
Got gauge pod ready to spray...
Old Oct 4, 2017 | 08:59 PM
  #99
smokinlmm's Avatar
Not much to it...
Old Oct 5, 2017 | 11:55 AM
  #100
Y-B-Slow's Avatar
Long tubes and a Y pipe are great supporting mods, no need to go 8 rib for 10#. Look into a blower pulley from Z-Industries when you pulley down. If you do happen to run into any slip it can usually be solved with larger diameter idler pulleys for more belt wrap. Meth is also not a must have to run 10#, cool build!
