TVS 2300 Cammed 6.2L Build
Old Feb 26, 2017 | 12:31 PM
  #81
03sierraslt's Avatar
Originally Posted by stroker87
would you be able to make more boost if you wanted to?
Just spin it faster. I have a 2.6" pulley for mine.
Old Feb 26, 2017 | 01:52 PM
  #82
terravast4's Avatar
what boost you seeing with the 2.6 pulley? how much power you putting down?
Old Feb 26, 2017 | 02:51 PM
  #83
That pulley is for the new motor, have a 2.9 on now and see 15.5psi with a 102mm throttlebody and phenolic spacer and port matched lower tub.
Old Feb 26, 2017 | 08:59 PM
  #84
shaw_426hemi's Avatar
i have seen the following boost levels with 3 pullies:
3.3" and stock crank pulley and idlers - 8psi
3 2" and 10% OD crank stock idlers -10-10.5psi
3.0" and 10% OD crank and metco 10mm -13-14psi
All are with a ported lower manifold and my cam, header, exhaust setup. Boost drops a lot with exhaust cutout open. Im wondering if a 3.0 is safe on stock flex pump with meth.
Tell me abouy the spacer, mainly for heat soak?
Old Feb 26, 2017 | 09:05 PM
  #85
I am running a 5/8" spacer. It helps with heat soak some and mainly raises the intercooler off the lower tub a bit to help when pushing it harder. There is a fine line IMO. I think too much spacer is detrimental but that's just my opinion.
Old Apr 3, 2017 | 08:45 PM
  #86
Truck is running good. I tjink i have a bearing going out on one of the Metcos or on the HD tensioner, going to check this week. With warmer weather im at 11-12psi @ WOT seeing fuel pressure at 45psi. I need to put limiters straps in next and maybe a driveshaft swap. She pulls hard for what it is, no clue on HP #s, any guesses?
One question, i noticed my fluid pump was not pumping, while trick was running, before i start digging is it temp related or continues pump for the heat exchanger pump?
Old Apr 3, 2017 | 08:56 PM
  #87
sledaction 198's Avatar
Hhmmm 11-12 pounds i would estimate it to be 575-625 whp maybe. You need a fuel system and E85 to have some more fun. Keep me posted on what you do on a driveshaft. Maybe we can get a better deal if we ordered 2 at the same time.
lxcoupe
Mar 2, 2016 04:14 PM
Chevyssr1997
Mar 2, 2016 11:46 AM
kazfan30
Feb 22, 2016 01:42 PM
Maxmumboom
16
Apr 15, 2002 06:40 PM
