Turbonetics Hurricane Series
yep i just went from a .96 ar turbo to a bigger one with a 1.20 ar...wow what a difference it made...this is the best my truck has ever been and it's been alot...
Could you explain what you mean. I've been looking at bigger turbos, but haven't been around enough of them to know how a bigger ar effects everything.
A greater AR ratio means the hot side will flow more exhaust, therefore less back pressure. More flow means more power on the high end. On some setups if its too restrictive, the turbo will prevent the engine from ever reaching its maximum power potential. Moving up in turbine housing size can fix that.
It sounds like it feels different. I want to know about SOP, I know it will make more power being more in the sweet spot of the turbo. I dd my truck, and want to know how a bigger ar would change how it feels to drive.
Bigger AR will make boost more like a single turbo swapped Supra does
It'll take longer to spool, but when it does it'll hit hard as hell. Seat of the pants fun will wait a little longer but it should feel stronger when it does come in.
I had a 1.32 AR on my 6.0 and swapped to a 1.10. The 1.10 is definitely softer...it might be a little deceiving since you feel the boost sooner with a smaller housing. The bigger turbine housing feels like driving an NA vehicle for the most part, until you hold the throttle down long enough and then boost comes in pretty violently. It was just merciless on the tires with the bigger housing. Now I can judge a little better when I'm about to break loose with the smaller housing because its not so violent.
