Turbo Upgrade....Worth it?
I've got the stock T-60 that came with the STS kit and I was wondering if the T-67 would give me any gains if I'm running the same amount of boost?
From what I understand it should help without any real downside. I think its a lot more efficient. I'm not sure if I would spend the money though, you can get a 6.0 complete engine barely used for $1500 or less. Good luck.
I wouldn't do it if your not going to turn up the boost. All your doing is increasing the capacity of the compressor, and making it slightly more efficient. I don't think you would see any, real noticeable power increase.
A T-67 is nothing more then a T-60 with a different compressor wheel and the housing machined out for it to fit.
9 Second Truck Club
You have meth and an intercooler, you can run 10-11 psi on a good tune with out any problems
I will be cranking the boost up to 10psi and that's why I was wondering about the turbo upgrade. I have to get my FLT tranny first since I've still got the stocker
. Would heads be the next mod after I crank up the boost????
I'd just keep turning you the boost till you break more parts
No need for heads, until you get really extreme on a FI motor. Parish has shown you can make lots of hp on stock motor with only a small cam and 15 lbs of boost. Probable more then a FLT Lv 5 can handle. No since throwing money at things like heads when you still have more turbo left.
You've got a good setup going there, if your gona up the boost, I'd look into a T70 turbo and some 60lbs injectors and shoot for 15 or so lbs of boost. That should be in the neighborhood of 600rwhp with proper tuning. Also, since your running a STS, if you haven't already, wrap your exhaust pipes from the manifolds all the way back to the turbo. You won't believe how much of a difference it will make in spool up time.
No need for heads, until you get really extreme on a FI motor. Parish has shown you can make lots of hp on stock motor with only a small cam and 15 lbs of boost. Probable more then a FLT Lv 5 can handle. No since throwing money at things like heads when you still have more turbo left. You've got a good setup going there, if your gona up the boost, I'd look into a T70 turbo and some 60lbs injectors and shoot for 15 or so lbs of boost. That should be in the neighborhood of 600rwhp with proper tuning. Also, since your running a STS, if you haven't already, wrap your exhaust pipes from the manifolds all the way back to the turbo. You won't believe how much of a difference it will make in spool up time.
