turbo upgrade recomendations
#41
The spring had it making too much psi for what I wanted. I took it apart and found the diaphram to be torn. I didn't have the correct springs so I just bought local and put the 8 psi spring in it.
While I was there I went ahead and swap turbos as well. Couldn't pass up the deal I got on the 76. It's not a precision 76 just another mp cast jb. If I feel like I still want to change I'll sell both of the snails and get what I want. But I'm going to give this a shot first and ill install a cam next before any turbos get changed out again.
It's not exactly the order I wanted to mod but I kinda had to change some stuff up on the fly.
#46
Well guys, I couldn't be happier with the truck. I can't wait to get a cam and stall in andet her rip again. Guna try to make it on a dyno in the coming weeks to get a baseline at the 10-11 psi I'm running now. Tuner said he could get more out of it but I told him I wanted safe and that's what I got.
All I need to do now is sell my other turbo and start getting my parts together for a cam swap. Then I can get a stall in it and relly wake it up.
Any other questions just ask and I'll be happy to answer them.
#48
93 pump
Just a stock eng/trans with a trick kit and 76mm jb turbo .81 exh a/r full spool at 3100 rpms according to data logs. 8psi spring. Gauge showing 10-11psi at wot.
Do not have before numbers. Looking to get on a dyno in a couple weeks with turbo kit. I assume it was putting down what a reg stock 5.3l does from the factory. Did not have time to get to a dyno and back before installation.
#50
Will do. Trying to get a few veh's to all go at the same time to save everyone a little cash. A couple pulls each for 75 bucks isn't really worth the trip. It's a decent drive to lake Charles from beaumont lol
