turbo upgrade recomendations
Old Jan 7, 2014 | 01:23 PM
  #61
Choda's Avatar
Originally Posted by Underdogg
I figured I could do it all at one time and get it tuned at once for the trans and cam... Is that the way it's usually done? I figured with the cam and turbo on a stock converter would be too much and it wouldn't be right on the dyno. Will it ruin the converter doing that? Or can I run the stock converter for a little while untill the new piece gets shipped to me? I'm only looking at the isky triple 12 or the tu0 cam. Nothing crazy.
I doubt it "too much" for the stock tc. I would say get a 3000 stall from a vendor and do it all at once. One tune for everything. There were a couple nice used ones in the classified too
Old Jan 7, 2014 | 01:48 PM
  #62
Atomic's Avatar
I have a gauge for that
Originally Posted by Choda
Something doesn't make sense. It should not open at all before boost. What spring do u have in the gate and what max psi do u see? Mine starts to open about 2-3 psi before max boost is met.
Not exactly...if you have very high back pressure and a weak spring the gate could easily be opening before you see boost.
Old Jan 7, 2014 | 02:42 PM
  #63
Underdogg's Avatar
How would I know if a 3000 is what I need? I would just hate to install it and it not suite the combo and me not like it.
Also is there any brands/kinda to absolutely stay away from? Or are they all about the same-ish?
Old Jan 7, 2014 | 05:38 PM
  #64
Choda's Avatar
ok ok. I hear ya, the lowest spring I have had in my truck was a 4lb and it started opening at 2psi. my 6 psi opened at 4ish. 8psi opened around 6 and so on. if he has a 8 psi spring in the gate and a regular exhaust that he prolly has being turbo then it should not open when still in vacuum. Right or no?
We have very similar setups and I have a 3000 stall and love it. I wouldn't go any higher or lower.
Old Jan 7, 2014 | 06:01 PM
  #65
Chevy_King1500's Avatar
I have the 3lb and 1.5lb springs installed in my waste gate.. truck made 6psi through 3" dp full exhaust magnaflow muffler
Old Jan 7, 2014 | 06:06 PM
  #66
Underdogg's Avatar
im making 10-11 through a 3in dp with a 8 lb spring in the gate. it opens just a tad before full boost tho. just a few rpm before 3100 when I hit full spool
Old Jan 12, 2014 | 07:22 PM
  #67
Underdogg's Avatar
now that I have put a few hundred miles on the truck I think I am going try and get the exhaust to be a tad bit quieter. I is a 24in long full 4in diesel muffler on it now and that's it. while it is manageable at idle I think when im cruising around id like to hear less of the exhaust.
could I just put another 3in resonator in front of the muffler? the muffer dumps just before the rear axle so I should have plenty of room to have one put there. I just don't want to have too much restriction on it and loose any power.
what is everyone doing when running a turbo? or is it just that everyone is running loud *** open pipes? lol
Old Jan 15, 2014 | 10:19 PM
  #68
redhotev1's Avatar
My tuck is loud too, I have 4" to two 3" straight through mufflers, turn out in front of rear tire, and I can't stand it, I'm going over the rear axle next!
Old Jan 16, 2014 | 09:19 AM
  #69
Underdogg's Avatar
Well crap lol. When I get back in town I will take it in and see what the recommend. I know it won't be as quiet as stock if just like it a tad bit quieter. Hopefully I can get it worked out.
Old Jan 16, 2014 | 05:50 PM
  #70
Choda's Avatar
check out my exhaust threads
