turbo truck heads lq9
i bought a pair of lq9 heads for really dirt cheap new. will these fit on a 5.3l or do i have to change the intake? and if they do fit any sugesstions on getting the done up for a turbo application, valvea, springs rockers,ect?
Heads will bolt right up, make sure you order 5.3 head gasket though, As far as a turbo app you're probably going to want to get a cam, set of comp 918 valve springs and some one peice comp push rods. your stock rockers are roller and will work just fine. Good luck!!!!
He's gonna want 6.0L gaskets. The combustion chambers in the 317 heads are larger, and you don't want gaskets that are smaller. A good set of springs is a must, along with some hardened pushrods. I personally would go with something other than the 918 springs, but that's just me. Stock rockers generally do pretty well, so don't worry about that.
they still make the 918, but they had a big recall so they are on backorder with the updated ones. the company that originally made the springs for Comp is making them again for themselves. but things being the way they are, you might wanna find another route depending on what cam you use. get the 6.0l gaskets, the heads have a 71cc vs 61cc chamber. your gonna love the drop in compression once you turn up the boost. rocker arms will be OK. what you wanna change is the pushrods, stock one suck from what i heard. just good insurance.
