turbo & towing
Old Jun 5, 2013 | 08:04 AM
fastlsx463's Avatar
Default turbo & towing
2000 rcsb, 4l80, 76mm, good intercooler.
would it be ok to tow a 2500lb race car on a trailer or bad idea? I'm thinking with headers wrapped and maybe removing inner fender wells to let heat out?
only around 10-12psi
any of u turbo guys tow? not alot, just here and there
Old Jun 5, 2013 | 08:20 AM
nonnieselman's Avatar
WHo tuned your truck?
Ive towed well over 2500# with my turbo truck. Prolly wouldnt hurt to take your passenger side inner fender out but if your tune is good then you wont have any problems.
Old Jun 5, 2013 | 08:47 AM
thunder550's Avatar
High on diesel fumes
You'll be fine.
Old Jun 5, 2013 | 10:14 AM
gamble686's Avatar
Several guys on this site tow regularly with their turbo trucks. You should be fine just keep an eye on your temps and don't get too crazy.
Old Jun 5, 2013 | 10:50 AM
Jake99's Avatar
I haven't towed much with mine yet but I wouldn't be afraid to, like stated its all in the tuning, as long as your part throddle boost af/timing is at a safe spot you should be good to go. Just try and stay out of boost for a long time at once, just to much heat will build up.
For example
https://www.performancetrucks.net/fo...-truck-518312/
https://www.performancetrucks.net/fo...-truck-507542/
Old Jun 5, 2013 | 03:24 PM
Alpinestar's Avatar
You might put in a 6lb spring for towing.
Old Jun 5, 2013 | 03:33 PM
or the lightest spring for towing and a boost controler for fun.
Old Jun 5, 2013 | 03:41 PM
thunder550's Avatar
Wastegate delete IMO.
Old Jun 5, 2013 | 03:55 PM
Alpinestar's Avatar
x2
