Turbo towing
Old Sep 26, 2008 | 08:49 AM
WJ MARK's Avatar
You should be ok! I tow with mine all the time. Just try to not be in boost for long periods of time
Old Sep 26, 2008 | 09:18 AM
Gordy M's Avatar
If you just pulling an open car hauler, you will not be in boost that much of the time. I pulled an open trailer thru WVA, VA, NC several times without any problems, when I went to an enclosed trailer is when you need FI, weight increase and so does drag. Inspect you brake pads/rotors and add fresh brake fluid before you start.
Old Sep 26, 2008 | 05:21 PM
xxwackerxx's Avatar
yeah ill probably be pulling 5-6k not sure yet...i got a 3 guage pod with boost, fuel pressure and egt...how much and whats involved in a a/f gauge. and whats a wide band? sorry i feel dumb when i dont know half this stuff.
Old Sep 26, 2008 | 05:24 PM
viciousknid's Avatar
Where's the Beef?
A/F gauge is the wideband. new is about 200-300 for a gauge and sensor. Used for about 100-150.
All you have to do is weld a BUNG into the exhaust so you have a place to hook it up. get a piggyback fuse and plug it into your fuse box, and ground it.
Took a couple minutes to install mine.
I'll show you a good place to run the wires as soon as I upload the pics off my phone.
Old Sep 26, 2008 | 05:33 PM
Where's the Beef?
Here's how I ran mine. Just run the wires under the plastic and up the dash.
Old Sep 26, 2008 | 06:12 PM
1BadAction's Avatar
Registered abuser
a good meth controller will have an input for a pyrometer. When it starts getting too hot, it dumps meth, regardless of boost. Makes a great failsafe for a turbo'd truck thats still used like a truck.
Old Sep 26, 2008 | 07:00 PM
xxwackerxx's Avatar
nice pics. thanks...whats considered a good meth controller? ill have to peak at mine an let you know if mine is good or not...also what kind of power am i lookin at makin on this setup on 5psi?
Old Sep 26, 2008 | 07:04 PM
xxwackerxx's Avatar
i looked at it i dont know what to look for but its STS...if that tells ya anything
Old Sep 26, 2008 | 08:28 PM
Wilde Racing's Avatar
How do I change this text
which meth controller offers egt spraying?
Old Sep 26, 2008 | 08:47 PM
1BadAction's Avatar
Registered abuser
alcohol injection systems is one of them.
here is a blurb from their site:
Users can also turn the system into a two demensional system by including any of the following 0-5v inputs; TPS, MAF, MAP, EGT and AIT, for even greater control and custom mapping which isn't offered by the competitors systems.
What you can do, is have a boost ref. for your main progressive meth curve, then set the 0-5v input to dump meth when the egt goes above a set temp.
