Turbo Temps...??
Old Jul 3, 2007 | 06:39 PM
nonnieselman's Avatar
Default Turbo Temps...??
What temperature is not good for a turbo??
Just wondering, I got this cool Fluke Temperature thingy from work today and went driving around town for a few mintues and got back and started shooting everything... (laser temp thingy... pretty neat)
Turbo>
Hot Side-216*F
Cold Side-118*
Exhaust Manifolds-274*F
Charge Pipe- 85* at the TB and 112* at the Turbo.
W/A Intercooler Inlet-105* Outlet-84*
Just curious,, cause 216* aint that hot for an exhaust piece.
Old Jul 3, 2007 | 10:18 PM
Spoolin's Avatar
GFYS and STFU
Definetly not hot. Were you stomping on it before you got home or were you under load much? How long after your drive did you use it?
We use that heat sensor at work on our marine engines and we see our manifolds reach 390*F on average on Medium speed diesels. Under full load they get alot hotter.
Old Jul 4, 2007 | 12:15 AM
Stoichiometric's Avatar
Under boost and load you would see over 1000*F in the manifolds. Front mount tubular stainless turbo manifolds glow nearly translucent under boost, and the turbo gets all that heat. As long as your oiling system works good, your sts should be happy.
Old Jul 4, 2007 | 02:02 AM
It was just a casual 15min drive around town being nice and not drawing any attn ( grandma driving)
but i just got back from taking a few friends for a spin...
Manifolds were bout 500* and the turbo was bout 475*...
Old Jul 4, 2007 | 08:20 AM
Spoolin's Avatar
GFYS and STFU
Ok that sounds better! I wouldn't imagine they would get as hot as Henry was indicating front mounts get but they will get rather hot. I wish I would of remembered to of brought my temp laser when I was towing my sled's up to the mountains, I'm sure my turbo got a little hot after being under load the whole time!
When I had my Typhoon I'd see my turbo get discolored after some hard driving and have seen pictures of housings glowing red where you can actually see through them and see the turbine spinning. That was a front mount and ours dissapate heat much better anyways.
Old Jul 4, 2007 | 11:21 AM
cpelton's Avatar
isnt 1200* the limit for egt? then you start melting things.. with the turbo in the back I can put my hand on it 10 minutes or so after driving.
Old Jul 6, 2007 | 10:01 AM
Lord Aries's Avatar
Crusing at 85mph my egts are between 1,100-1,200* and have been like that for a little over 2 years with no problems... So far... :-\
Old Jul 6, 2007 | 10:06 AM
ZZebes's Avatar
For diesels, diesels have lower EGT's than gas motors just by nature of there design and combustion.
Old Jul 6, 2007 | 11:14 AM
cpelton's Avatar
ahh i thought that might be the case.. so what is the limit on gas?
Old Jul 6, 2007 | 11:28 AM
Lord Aries's Avatar
I just remembered someone telling me that any constant hightemps over like 1,400* was starting to push it too far and that 1,600* was the failure point... But, I may not be remembering that quite right... :-P
kha4079
Oct 29, 2018 04:38 PM
lxcoupe
Sep 6, 2017 08:24 AM
jtphelps289
Sep 11, 2015 06:37 PM
slowswb
Sep 5, 2015 02:27 PM
06murder
Sep 4, 2015 03:54 PM
