Turbo suburban
New to the LS world..
Recently purchased an 02' z71 suburban. Stuck a cam, springs, wires, and push rods in her, put 4.88s front/rear, dyno tuned it on 35's and she put 346 to the ground. 5.3L I should mention.
Just purchased an on3 kit.
-76/65 journal turbo
-80lb injectors
-dual pump
-11psi wastegate spring
Also have a PerformaBuilt trans on its way as well.
Excuse me for my ignorance as I am fairly new to the turbo and LS world, as well as this forum.
I'm on a budget with this vehicle (obviously with the purchase of the on3 kit)
Question is: What am I missing, anything I should add, and what are the results that I should expect..
Thank you in advance for all of you fellas time and input👍🏼
-80lb injectors
-dual pump
Apples to oranges, and hopefully your turbo flows better: but I made 477 on 12lbs with a P1SC. 2002 5.3, completely stock exhaust and an LS9 cam
Its about flow, not psi, so if that turbo flows more than the P1, you will make more power at less pressure.
Id say high 400s, low 500s.
