which turbo(s)
Old Mar 23, 2007 | 03:17 AM
Default which turbo(s)
With what I have in my sig, which turbo should I go with and/or which twins should i go with?
Old Mar 23, 2007 | 11:22 AM
ss04flores's Avatar
Most people on here would say to go with the STS Turbo------->>>>>>
Old Mar 23, 2007 | 11:25 AM
BlownChevy's Avatar
blownerator
25 Year Member
I would say go with the STS turbo.....Give us a call and we can discuss it.
Old Mar 23, 2007 | 11:37 AM
Wilde Racing's Avatar
How do I change this text
Are you going to tow anything? how much do you go offroading? How much HP are you looking for? What have you done to your trans?
Old Mar 23, 2007 | 12:33 PM
BlownChevy's Avatar
blownerator
25 Year Member
another good point, you will need to do some trans upgrades with any adder.
Old Mar 23, 2007 | 01:29 PM
I may tow a small camper trailer from time to time. I pretty much offroad every second weekend. Ill take as much hp that the stock bottom end'll take,
but I could always keep the boost down and when I do stroke it then i'll crank it up. I'm also looking at tranny options right now. I aint got the cash to lay down 5000g's on a kit so I was plannin on buying something of ebay and building from there.
Old Mar 23, 2007 | 01:31 PM
BlownChevy's Avatar
blownerator
25 Year Member
Buying an ebay kit will end up costing you 5000 in the long run.
Old Mar 23, 2007 | 01:33 PM
Is the filter location of the STS kit going to be a problem with your off roading? and a front mount might get too hot while towing. Are you dead set on a turbo?
I wouldn't buy to much off e-bay, Unless they have customer support. lol
Old Mar 23, 2007 | 02:01 PM
Yeah some of the holes we go in kinda swallow the truck so I do need a front mount. Why will the front mount suck? diesels use em. Well a turbo will be the cheapest way to go, I already have a supercharger thats leaking at the seals with only 20 mins running with it. Paxton wanys $450us to rebuild it, so its not worth it for me to fix it if it ain't gonna give me the power I want.
Old Mar 23, 2007 | 02:26 PM
diesel exhaust temps are WAY WAY lowwer than gas engine temps. Not aying you can't tow with front mounts, you just have to be carfully of wire and hose routing, also watch for cracking manifolds...
