turbo progress
Old Sep 16, 2005 | 05:47 PM
  #21
dewmanshu's Avatar
Moderately Differentiated
I am no frabricator...don't even play one on TV...but I thought that all the primaries in the header had to be the same exact length....for obvious reasons of equalizing the gases and sound waves. I mean, otherwise everybody would just short cut the rear primaries instead of making them look like snakes on acid.
Work looks freaking fantastic....buuuutttt....
"When designing the tube pack routing, consideration should be made for equal length primary pipes (± 1/4" is good). This is much harder than it seems at first blush and when equal length is achieved, it is the mark of an accomplished header fabricator."
http://www.burnsstainless.com/TechAr...struction.html
Old Sep 16, 2005 | 07:14 PM
  #22
NA$TY-TA's Avatar
Turbo Director
Originally Posted by TIRBRNR
It's the 53 trim compressor which is the 74mm inducer. The turbine side is the T-4 .128 A/R housing. On Garrett's website I only see two options for the 42; a 56trim w/ a 70mm inducer/94mm exducer and a 53 trim with what I have already stated. I don't see 76mm inducer 42. Is that new?
Thats because its a Precision Turbo... made by Garret then redone with a76mm wheel and a T-6 flange.
Heres a pic of the hoss
Kyle
Old Sep 16, 2005 | 10:36 PM
  #23
Walker Morgan's Avatar
Apparently your not a speller either
First off, thank all of you for the compliments on the work on Curtis's truck. I'm very happy with it. I'll post more pictures soon.
If you look at most headers manufactured in the OEM/Aftermarket realm you will see that it is WAY more common to have unequal length header than not. Most of the time this is due to cost and space limitations holding precedent over maximum power potential, but even with these limiting factors most vehicles seem to get along just fine. That is not too say that equal length doesn't have its merits, but it seems to be more important with N/A applications than with turbo applications because of the pulses acting on each other ,in the collector, to induce scaveging. This intern aids in a N/A motors ability to breath. By stuffing air down the engine's throat with the aid of a turbo charger and the fact that it hard to "scavenge" anything out of the engine when there is a cork in the exhaust system, i.e. the turbo, the merits of equal length are reduced. Space limitations on this particular truck and my own beliefs (above) are why I built the headers the way I did. I'm sure Curtis will have more than enough power to scare the crap out of himself with this system.
One last thing. See if you can wrap your head around this one. Almost always a tubular manifold is better than a "log" style manifold, whether forced induction or N/A. Parrish has a "log" style manifold on his current set up I believe. It doesn't seem to be holding him back at all.
Old Sep 16, 2005 | 11:06 PM
  #24
Here is a link with all of the pics so far.
http://meacham.pointclark.net:192/gallery/TURBO-TRUCK
Old Sep 16, 2005 | 11:25 PM
  #25
moregrip's Avatar
what a rush!
absolutely beautiful!
Old Sep 17, 2005 | 07:49 AM
  #26
CurtD's Avatar
10 Second Truck Club
So...you must have slept at a Holiday Inn Express last night!
Old Sep 17, 2005 | 04:24 PM
  #27
duwem's Avatar
dude, that is some sick ****, really nice lookin headers and piping. When can I buy a kit?
Old Sep 17, 2005 | 09:47 PM
  #28
vanillagorilla's Avatar
This is true. Nice work man, where do I sign up. It's nice to see that you're using such thick walled stainless too. I doubt it will have any sag or cracks for that matter.
You really don't think you can post pics of this and not expect to produce them.
Old Sep 17, 2005 | 09:48 PM
  #29
dewmanshu's Avatar
LOL...nope...apparently not(being a speller). Just asking. It seems to always be a topic...equal length and all. As far as parish goes...holding him back...obviously that isn't much of a concern with a 1000+hp setup and trying to decide where to put each dollar of interest...however...what's another 45 to 50 hp when your talking over 1000hp huh.
I was just asking...it's very obvious by the pics, you know what you're doing. My bad for not noticing you were a spelling teacher as well.! Again...nice freaking work man. I'll try harder on checking my post for errors next time.
Old Sep 17, 2005 | 10:06 PM
  #30
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
When can I purchase one?
