turbo positioning question
Old Jan 10, 2010 | 03:07 PM
sowaidi's Avatar
Default turbo positioning question
i just received my gt67 to upgrade my worn 60-1 on my trucks STS system. the problem is my 60-1 has the exhaust inlet in the upward position and the outlet to the intake in the downward position. i received my gt67 which has both the outlet and the inlet in the same position. i am asking this question before doing anything. can i just unscrew the bolts and turn either the turbine or the compressor about 180 degrees to the desired position of my downpipe? im thinking its something simple since its just a matter of turning it and screwing it again however i was advised by a friend to not touch a bolt on the turbocharger because that will ruin it.
im not in the US so shipping it and waiting for another one is a pain.
Old Jan 10, 2010 | 03:16 PM
SLO TRUCK's Avatar
Yes you can loosen the bolts and re index it.
Old Jan 10, 2010 | 03:57 PM
LsxCody's Avatar
yup its an easy fix,just loosen the bolts up
Old Jan 10, 2010 | 05:26 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Position the turbo so the oil return is DOWN then reindex the two shells. There are 6 bolts holding a pinch plate to the shell with the edge of the center housing between then. Loosen the six bolts and slide the shell to the desired position.
Old Jan 11, 2010 | 04:25 AM
sowaidi's Avatar
i just need to shorten the oil line a bit. i turned the compressor. cant wait to try it out and tune it.
Old Jan 15, 2010 | 06:55 PM
acethedragon's Avatar
ok just make sure your oil feed is on top and drain on bottom. this is very important when reclocking the housings, make sure the centersection is clocked properly too. good luck and have fun with the upgrade
5.3lSilverado
25
Aug 29, 2016 12:48 AM
Denali08
Aug 9, 2015 04:34 PM
hartinclay
Aug 2, 2015 06:44 PM
USMCvet0311
Aug 1, 2015 07:45 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
