turbo plus nitrous.
Old 08-09-2011, 05:19 PM
00rcsb's Avatar
why stop spraying nitrous? Would there be harm to continue spraying? Of course with a good tune.
I was wanting to continue spraying through entire pass.
Old 08-09-2011, 05:25 PM
Truck Sponsor
TrickTurbo's Avatar
No need to stop.
Most just want help out of the hole.
Old 08-09-2011, 08:22 PM
kazfan30's Avatar
Originally Posted by TrickPerformanceProducts
No need to stop.
Exactly... plus you can shoot it on the Turbo tune on little to know boost but 100 shot on top of 10 or more pounds gets kinda scary to me.. but it can be done
Old 08-10-2011, 04:18 PM
00rcsb's Avatar
I was just wondering thanks. We plan on spraying entire track. I just didnt know if it would do harm to the turbo or by doing so. I planned on doing a 100 or so dry in front of turbo and maybe a little wet kit on top of 10-15 lbs of boost. Trying to go after that et you know
Old 08-10-2011, 04:43 PM
Truck Sponsor
TrickTurbo's Avatar
No need to mis with dry stuff. If u are thinking wet.
A big pro to wet kit in this application is the added fuel. If you want to make a tune up change then swapping a jet out is alot quicker then retuning the ecu.
Plus now u have set up a secondary fueling sorce if need be.
U can even have a t in line to add a tad more fuel to #7 hole if you want.
Old 08-10-2011, 11:23 PM
bansheerider44's Avatar
i sprayed 100 wet on a wot switch the whole track to my 6.0 and loved it. was a forged motor tho, so was not real worried about it. It works great
Old 08-11-2011, 07:39 AM
nonnieselman's Avatar
I ran a 47 shot on top of 6psi on my LQ4. Added 64rwhp and 90rwtq on the dyno thru a 80E.
It took me from a 13.2 to a 12.5 in the quarter.
I went to 10psi and never ran on the track with it but it would start spinnin in the top of 2nd so i never tried it again.
100 shot in top of 10psi is gonna make a huge difference. Might want to start at a 50 shot and work up.
Old 08-11-2011, 04:21 PM
00rcsb's Avatar
Reason for the dry kit, and correct me if my thinking is wrong. But wouldn't that help with the cooler iat temps? We are limited on room being in the s-10 blazer and will be running the biggest front mount we can fit (still smaller than many use on the fullsize). I was thinking that the wet kit mainly would just be used as an equalizer for when we have to lay the smack down. lol But if a wet kit will also help lower the IATS (I have a dual stage nitrous outlet plate kit) than I will use it. But I planned on dry kit in front of turbo. I won't be running an air filter (just a screen) as the turbo inlet will be in the fender.
Old 10-22-2011, 07:30 PM
Midnight's Avatar
What about using a plate style setup on a front mount turbo kit?
Old 10-22-2011, 08:09 PM
Truck Sponsor
TrickTurbo's Avatar
Your good to go. Just make sure you use the proper jetting.
Modify jetting us quick and easy with a plate.
Fuel psi to plate must be off fuel rail or if using a standalone boost reference the regulator.
Who's plate?
Quick Reply: turbo plus nitrous.
