turbo plus nitrous.
I was just wondering thanks. We plan on spraying entire track. I just didnt know if it would do harm to the turbo or by doing so. I planned on doing a 100 or so dry in front of turbo and maybe a little wet kit on top of 10-15 lbs of boost. Trying to go after that et you know
Truck Sponsor
No need to mis with dry stuff. If u are thinking wet.
A big pro to wet kit in this application is the added fuel. If you want to make a tune up change then swapping a jet out is alot quicker then retuning the ecu.
Plus now u have set up a secondary fueling sorce if need be.
U can even have a t in line to add a tad more fuel to #7 hole if you want.
I ran a 47 shot on top of 6psi on my LQ4. Added 64rwhp and 90rwtq on the dyno thru a 80E.
It took me from a 13.2 to a 12.5 in the quarter.
I went to 10psi and never ran on the track with it but it would start spinnin in the top of 2nd so i never tried it again.
100 shot in top of 10psi is gonna make a huge difference. Might want to start at a 50 shot and work up.
Reason for the dry kit, and correct me if my thinking is wrong. But wouldn't that help with the cooler iat temps? We are limited on room being in the s-10 blazer and will be running the biggest front mount we can fit (still smaller than many use on the fullsize). I was thinking that the wet kit mainly would just be used as an equalizer for when we have to lay the smack down. lol But if a wet kit will also help lower the IATS (I have a dual stage nitrous outlet plate kit) than I will use it. But I planned on dry kit in front of turbo. I won't be running an air filter (just a screen) as the turbo inlet will be in the fender.
