Turbo oil feed source
Old Nov 15, 2011 | 12:13 AM
Rick_Vor's Avatar
Originally Posted by Atomic
It doesn't get much cheaper/easier than that. Unbolt, Drill, Tap, Install, crack open beer...
Rick
Old Nov 16, 2011 | 02:48 PM
WJ MARK's Avatar
That crazy unibomber guy in CO that makes them will be producing some for the oil cooler guys that will bolt in between
Old Nov 16, 2011 | 03:10 PM
Sierra1320's Avatar
Rick
X2!
Old Nov 16, 2011 | 03:16 PM
nonnieselman's Avatar
Atomic has a funny colored torque converter......
but thats the same thing i did on my turbo setup.. Drill and tap the blockoff plate for 1/8"NPT and put in a -4 fitting. vola.
Old Nov 16, 2011 | 03:58 PM
Atomic's Avatar
I have a gauge for that
All PI converters are purple, and all yanks are red.
Old Nov 16, 2011 | 07:51 PM
Dbyers2's Avatar
formery SilverSleeper1500 (12-06-2011)
How much oil is expected to drop when taking off the original block off plate
Old Nov 16, 2011 | 07:54 PM
kbracing96's Avatar
Originally Posted by SilverSleeper1500
How much oil is expected to drop when taking the plate off the original block off plate
A lot, it pretty much drains out the whole oil supply system of the motor, all the oil passages and everything. Let just say, have a catch pan ready
Old Nov 16, 2011 | 09:16 PM
Atomic's Avatar
...or just let it sit for 6+ hours before you do it, that way most of the oil will be in the pan
Old Nov 22, 2011 | 04:20 PM
M&M Turbochargers's Avatar
on the master power and magnum turbos an 1/8th in pipe fitting threads into the feed side , so i didnt need to use any flange on the feed side
Last edited by M&M Turbochargers; Nov 22, 2011 at 04:21 PM. Reason: not sure if it was npt , but was from hardware store
mhorn0817
Jul 8, 2017 01:54 AM
chopperloco
Jul 10, 2016 10:45 PM
DrX
Aug 11, 2015 07:25 AM
Mzay
Jul 6, 2015 11:03 PM
