Turbo+n2o
What is the most boost and N2o I can run together with a stock bottom end.. I have a 5.3l from an 06 sierra with a 212/218 115lsa cam, in my 01 Silverado..
Just curious.. dont wanna blow anything...
well you could do damage with boost only, or with nitrous only, there is a fine line between how much boost and nitrous.
How much boost are you running? Want to run? What is your setup? Start there and then maybe add a little juice to spin it up faster, good tuning required.
I'm just trying to bust your *****.
Anyway, what is your reason for running nitrous? Are you having a hard time getting it to spool? What size turbo do you have? Meth might be a better option if you're trying to fight high IAT's.
I had the kit before I put the turbo on.. I Wanna keep the iats down and try to get a little extra outta it if I can.. Lower et's.. But If turning into a meth head will be better for it.. Might wanna go that rout.. I run my quads off that.. so an endless supply is available..lol
