Turbo Maybe?
Old Jul 24, 2008 | 12:02 AM
00Silv4.8's Avatar
Originally Posted by Parke10
why not bottle feed her?
I would but its still a little pricey IMO. And then I dont even know where the hell to get a bottle filled here haha
Old Jul 24, 2008 | 12:03 AM
dirt track racer 81's Avatar
Originally Posted by 00Silv4.8
Thank u Tyler...
THATS y I want to piece mine together. I just had a buddy with an Eclipse GSX just redo his turbo, all the piping, exhaust and custom front mount. I wanna spend LESS than a G.. thats all the credit card will handle, haha
yep we used an exhaust pipe bender to get all the bends right
Old Jul 24, 2008 | 12:05 AM
00Silv4.8's Avatar
wow thats even better than cut piping and welding.. Awesome..
I need to do more research, pay off my credit card and wait about another month. Thanks Tyler, I am now an inspired man...
Old Jul 24, 2008 | 06:38 AM
Moddoo's Avatar
I hate to bring reality into this thread, but your truck does have a stock 4l60e, correct?
I have many resources to build a turbo setup.
Fuggin trans worries keep holding me back.
Old Jul 24, 2008 | 12:29 PM
built408's Avatar
haha, thanks dick
The only reason y I said piece it together is cuz it doesnt seem like a big problem to me. Get a turbo.. Either buy the piping and manifold or just buy the manifold and build the piping (simple enough) then put it all together. Run some oil lines, get a new fuel pump and bigger injectors maybe, and its done. 5-8 PSI turbo is complete?
If only turbos where that easy and cheap.... Your forgetting ALOT of stuff. Wideband, boost controller, bov, wastegate, intercooler, tuning, and TRANS. You might want to do some more research, TURBO AND CHEAP DONT GO TOGETHER!
Old Jul 24, 2008 | 07:05 PM
t_thall's Avatar
He is very right, i've tried it twice now, it usually ends up costing about 2 to 3 times what you figure!!!!
Old Jul 24, 2008 | 08:11 PM
00Silv4.8's Avatar
u guys arent seeing it how I am. A whole kit from STS or Trick is upwards of 4500. I can buy a turbo, fuel pump, injectors, then make some piping, maybe buy and intercooler and get some rubber hose for oil and be relatively close to or under a grand. I obviously know my trans will probably let go. KBracing96 had a relatively stock trans, and his held up for quite awhile. This is just an idea Im toying with. I may just do my heads and risk the truck being down, Im not sure yet. I've got a friend who pretty much fabricated all his **** for his Eclipse aside from buying an intercooler, turbo, fuel pump, injectors and some tuning/scan handheld thing. He spend just about a grand
Old Jul 24, 2008 | 08:41 PM
nightrunner's Avatar
Mr. Obvious
dude, even though they are both turbo setups, your truck and an eclipse is waaaay different.
why do you think your truck will blow if you add heads? just makes it more efficient. for more power under a grand id look at n2o. or maybe some more supporting mods for your current setup, gears maybe, stall?
Old Jul 24, 2008 | 08:53 PM
GMChasLS1's Avatar
Originally Posted by dirt track racer 81
i built one out of exhaust tubing for my old bosses 87 gmc..he had less than a grand in it..it was a remote style..the ebay turbo is now too small for the 6.0 he has in it now..has worked flawlessly for the last 3 years now..the guys that came to the okla truck gtg to see it on the dyno with the old turn 5.7 in it
That thing runs great! I kinda felt sorry for the poor little stock old school 350 pushing 15PSI to it!
Old Jul 25, 2008 | 03:08 AM
geestyle4's Avatar
lmao under a 1000 dollars for a boosted truck hahahaha iam gonna die well lets see for my truck hmmmmm i spent about a 1000 bucks in just things needed before turbo and thats not including trans.(already have a built unit) just alone a tune is 500 so if you can find a turbo that isnt made out of pots and pans for 500 bucks then you just need hmmmm everything else!!!!
