Turbo LSX 2011 Escalade EXT build
Old Jan 3, 2015 | 12:26 PM
  #111
George C....'s Avatar
Formerly ScreamingL
Originally Posted by blownescalade62
Not sure what setting were. Washer 50/50
Julio's pumps arent meant for water use....Hell void the warranty if you use anything but 100% meth
Old Jan 3, 2015 | 12:49 PM
  #112
blownescalade62's Avatar
Really I did not know that?
Old Jan 3, 2015 | 12:55 PM
  #113
Formerly ScreamingL
he states it when you talk to him on phone, his site used to mentioned it as well.
His kits are supposed to be ran on 100% meth and tuned by his tutorial
Old Jan 3, 2015 | 02:15 PM
  #114
Well I pulled this off his faq page on his website.
Quote
Can I use windshield washer fluid?
If you can ascertain the chemical composition of the windshield washer fluid where by it doesn’t have any soap or chemical that would be detrimental to the operation of the vehicle, yes. Examples are winter formulas that use 50-100% concentrations of methanol.
End Quote
So I would say your statement in not true.
Old Jan 3, 2015 | 05:19 PM
  #115
Formerly ScreamingL
Quote
End Quote
actually that statement is vague, not all of those washer mixes are the ones needed but its also your setup and hell not fix the pump from the use of water or washer fluid
been down this route 7 yrs ago
Old Jan 9, 2015 | 05:29 PM
  #116
Updated videos page 10 of dyno
Old Jan 10, 2015 | 11:36 AM
  #117
HP52TA's Avatar
Bad a$$ build man. You really stepped it up.
Can't image what she is going to be like to drive, after feeling the effects of the junior kit at 8Psi. Should be a monster.
Old Jan 10, 2015 | 02:03 PM
  #118
DrX's Avatar
DrX
I can't see any meth kit pump not being intended for use with water considering that an approximately 50/50 mix is optimal for knock suppression. At 100% you are using the meth to supplement an inadequate primary fuel system.
Good to see another local build on here!
Old Jan 10, 2015 | 03:39 PM
  #119
Formerly ScreamingL
not exactly true, youre using 100% to cool and use it for its octane
not all meth kits and pumps are created equal
so to say its a bandaid is far from the truth, some of the fastest cars in the world run on pure meth for a reason. Spraying pure meth is along the lines of that route
its basically having a dual fuel setup
Old Jan 11, 2015 | 08:17 PM
  #120
Exactly they aren't! Most pumps cant run 100% Meth. Julio's pumps can. But to say you can not run 50/50 mix is rubbish! Water and Meth is much easier on the pumps then a 100% mix.
